[Sammelthread] DFI LANparty UT 790FX M2R / M2RV (AMD 790FX) [1]
Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
IV. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
Hab das 1.16 BIOS auch mal drauf gemacht und keine Veränderungen bemerkt.
Bei HTT305 ist schluss.
Is aber auch der Brisbane ...
Vista will nicht mal mehr bei 300 booten!
Muss mein Profil auf 277x11 zurücksetzten.
Wo ist eigentlich der Unterschied zwischen CPU NB Voltage Control und NB Voltage Control?
Wie sollte das 1. bei nem Brisbane einstellen?
das erste sollte beim brisbane keine rolle spielen...
bist du mit früheren biossen höher gekommen mitm htt?
Seltsam... haste den HT Multi mal runtergestellt? CPU NB Voltage ist imho der IMC, NB Voltage ist die NB...
Übrigens laufen meine 4GB endlich stabil :d
jo nicht schlecht^^ gratulation..
Nö, war schon immer so!
Interessant ist, dass die 300 auf XP tip top laufen und Vista damit nicht mal bootet.
Bleibt beim Ladebalken stehen ...
Welche Spannung sollte man beim IMC einstellen?
Also ich habs auf Default... Man könnte mal versuchen nen paar Prozent hochzugehen, aber ich kann mich noch erinnern, dass mein Lima (Singlecore, G1 Stepping) auch bei ziemlich genau 300MHz nicht mehr höher wollte, egal was ich angestellt hab...
also an sich sollten die boards echt je nach prozzi (und eingestellter nb/ht-link frequenz) schon ihre 300+ laufen...
mit phenom kann es eben sein dass die nicht so hoch gehen.
ach so ein tipp noch: alle tref-werte auf den gleichen wert stellen (75ns/105ns/127,5ns/195ns), auch der leeren bänke, das mag der imc. hat bei mir beim f3 schon geholfen über 300mhz htt zu kommen und mache ich seitdem immer so...
Edit:
Seite übersehen
Gar nicht, sollte es beim Brisbane gar nicht geben, nur beim Phenom. Haste die TRFC auf 195ns gestellt? Das braucht man für hohen HTT.
Hast du das auch mit maximalem htt getestet?
Mehr TRFc = mehr htt
(bloß halt nicht bei meinem phenom...)
Ja, glaub allgemein nur bei Athlon, aber er hat ja nen Athlon.
@ Faint
Für max HTT scheint man unabhängig von den ICs 195ns aufwärts zu brauchen.
ich hab mit 105ns getestet bei den microns glaube ich..
@neues Beta bios
:hail::hail::hail::hail::hail::hail::hail::hail::hail::hail::hail::hail::hail::hail::hail:
Der grund dafür kommt in etwa ner 3/4 h wenn S&M fertig iss :d (und vista x64 das durchlaufen lässt)
hat einer von Euch schon ein neueres DFI im Einsatz
z.B. DFI LANparty DK 790FXB-M2RS/H
mein UT 790FX taugt nix, egal welches Bios
war eins der 1' sten Montags-Boards
hab den x4 9550 auf einem anderen Board mit 770 chipsatz auf Anhieb bis 270 HTT gekriegt, bei meinem DFI ist bei 235 HTT Schluss :(
Hab heute das 790GX-M2RS bekommen, aber noch nich umgebaut.
Für sowas gibts nen anderen Sammelthread...
Verdammt eingeschlafen :fresse:
  1. Vor dem Beta bios gingen die 3ghz ganz sicher nicht mit der vCore @Vista x64 (funzte nichtmal mit 1.4V)
  2. htt 250mhz UNDDDD Rammulti 2!! -> 500mhz Ramtakt+ 3ghz cpu takt :fresse::fresse: Endlich
zu punkt 2:
Vorher ging der 800er rammulti nur bis etwa 235mhz und darüber nurmehr htt:ram = 1:1
Vll liegts auch an den 2Gb A-Data riegel die ich wegen x64 und GTA IV vor kurzem eingebaut habe... Aber die 800er powerchips (od. was auch immer) schaffen die ddr1000 und die d9gmh nit?!
nice!
die gmh müssten natürlich die ddr1000 auch schaffen...
Bei wem funzt Hotplug @E-Sata?
Hat wer nen tipp für mich? Das läuft einfach nicht bei mir (vista64 + xp32)
Wahrscheinlich stell ich mich einfach zu blöd an ... ^^
nie probiert..
gute tag und erst mal schönen start ins WE ;)
will vieleicht hier wer das board los haben ?? ;) hab intresse
oder vieleicht sogar tauschen gegen mein JETWAY
Beiträge zusammengeführt, da Antwort auf eigenen Beitrag innerhalb von 4 Stunden:
ähmm haste bei sata typ auf AHCI gemacht ?? das funtzt bei mir am anfang mit dem jetway auch nicht musste sata typ auf AHCI ändern und windows neu machen
Also bei mir funzt HotPlug (intern, also ohne esata ^^) am Silicon Image Controller problemlos (hatte es ma @ winxp 32bit getestet)... An der SB600 wirds nicht laufen mangels AHCI Unterstützung seitens DFI...
bei alternate ist es ab heute nicht mehr gelistet
