[Sammelthread] DFI LANparty UT 790FX M2R / M2RV (AMD 790FX) [1]
Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
IV. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
denke schon....
Im übrigen gibts sehr wohl ne neue Beta auf der DFI Site... vom 26.3.
Unterstützt angeblich die neuen AM3 CPUs inkl. X4 945/955 ;)
edit: lool, jetzt seh ich auch erst die 08 da hinten :fresse:
Naja, vielleicht ist es ja aber wirklich ne neue Version, nur dass sich nen Schreibfehler eingeschlichen hat... die Beschreibung deutet ja drauf hin.
ja haste die schon geflasht? ist nen bios von 2008 xD hatte ich schon drauf..
nee... auch wenn du dann wieder zurückflasht stehst da.. 26.03.2008 xD im flashprog unter current bios xD
ausserdem erkennt es den phenom II nicht.. kann also SO neu nicht sein LOL
Habs grad drauf... ich denk trotzdem, dass es neu ist. Auf der DFI Homepage steht ja auch 09 und die Beschreibung klingt auch gar nicht nach 08 ;)
Es erkennt den P II nicht? scheiße :fresse:
ist nen fehler von dfi.. 100%. lies doch mal mit everest das biosdatum aus...
die haben bestimmt nen neues gemacht und das alte reingestellt ;)
und wie gesagt, es erkennt den pII nicht. Und die nb muss wieder per hex eingestellt werden. 100% ein fehler da bin ich mir sicher wie nie ;)
ja hab schon bescheid gesagt...
So, hab das schöne DFI jetzt auch wieder drin :). Hat sich was beim Bios getan? Leider sind die ganzen Betas jetzt weg :(, spricht irgendwas gegen das vom 21.1.09?
Nee, 21/1 ist das Aktuellste!
Gab vor kurzem ne neue Beta, aber Öse meint dass das falsche File eingestellt wurde und es eine Version vom März 08 ist.
Ok, die Beta vm 20.1. oder 19.1. gefiel mir glaubich besser, als die vom 21., aber leider ist die nicht mehr online. Mal gucken wie das neue wird :)
DFI LANparty UT 790FX-M2R / DK 790FX-M2RS (790FX / SB600)
Forführung dieses Threads
Dfi LANParty UT790FX M2R/M2RS
***sammelthread***
II. Technische Details zum Board [UT790FX M2R/M2RS]
CPU
Chipset
Memory
Expansion Slots
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
Audio
LAN
IDE
IEEE 1394
# VIA VT6307
# 1 IEEE 1394 port
# 2 RJ45 LAN ports
I/O Connectors
# 1 IrDA connector
# 1 CIR connector
# 6 fan connectors
# 1 diagnostic LED
Power Management
# Wake-On-Ring
# Wake-On-LAN
Hardware Monitor
PCB
# ATX form factor
III. Layout
neuestes beta-BIOS (jetzt in der richtigen Version von 2009) ist auf der DFI-Webpage!!
Neuer Thread :) Hab mich schon gewundert, wieso der andere heut' Nacht auf einmal zu war.
Hast du zufällig bei deinem Phenom II mal die CPU-NB Spannung gemessen? Es geht darum, dass bei im Bios eingestellten 1,35V nur 1,23V CPU Spannung anliegen(mit Phenom 940 und dem neusten Bios) und wenn das bei der CPU-NB Spannung(die ich ja nicht auslesen kann) genau so wäre, hätte ich Angst um dem IMC..
mit dem neuesten bios noch nicht gemessen.. mach ich glatt mal..
---------- Beitrag hinzugefügt um 00:25 ---------- Vorheriger Beitrag war um 00:21 ----------
mmh also mit 110% sollten es 1,29v sein und es sind 1,3.. alles oki...
mit der cpu-vcore isses noch besser.. 0,864 zeigt cpu-z und das dmm exact auch im idle ;)
hab mich des threads mal angenommen nachdem er heute morgen dicht war xD
hast dus auch nachgemessen mit der cpu-spannung? oder zeigt cpu-z das nur an.. ist dein oc weniger geworden?
Sehr gut, neuer Thread :d Diesmal wird dann ja hoffentlich auch der erste Post etwas besser gepflegt ;)
Gut ist schonmal, dass das neue BIOS AM3 CPUs unterstützt... mein X3 kommt wohl übermorgen :bigok:
uh oh besser gepflegt ;) na hoffen wirs xD
evtl. verlinke ich die jeweils neuen biosse (wenn ich das durchhalte)
muss man sonst viel wissen? ich finde das board rennt einfach... :love:
zum ram oc könnt ich was sagen: mit gmh's rennt es bei hohen voltages (~2,2v) besser mit weak drive...
bei hohen reftakten lohnt es sich zu probieren cs/odt pin fine delay auszuschalten..
kriege mein x3 wohl auch morgen, ist aber für ein neues DFI am3 board gedacht dass auf dem Weg zu mir ist :p
Hätte lieber nen x4 955 genommen aber was solls. Und dann halt nen billigen 710er, muss das board schön schuften für oc ;)
Nein, ich komm' da im Moment nicht dran zum messen. Den 940er hab ich gerade erst eingebaut, also noch unter keinen anderen Bedingungen getestet.
Ich glaub an dich :xmas:
Kann das genannte nur bestätigen...
Du hattest ja auch mal erwähnt, dass der IMC identische TRFCs mag... war das für den Phenom gemeint? Weil bei meinem X2 kommt es auf den RAM an, hab mit sehr wilden Kombinationen bessere Ergebnisse mit meinen Dominators erreicht... (550MHz CL5 @ 2,09V, sonst keine Chance unter 2,2V)
Irgendwie hab ich das unbestimmte Gefühl das neue Bios läuft kacke. Hab jetzt mal das 505 geflasht und das scheint besser zu gehen. Es ist aber da auch so, dass ich im Bios 1,42V angezeigt bekomme und im Windows sind's dann 1,32. Vorhin wurde beim Start vom SG mal kurz 1,42 anzeigt und dann sofort bleibend 1,32. Hoffe mal da setzt nicht wirklich irgendwas die Spannung runter.
lol... versuch mal über % die spannung zu erhöhen...
Mach ich ja, ich stell CPU und CPU-NB Spannung auf den Standardwert(1,35/1,175V) und erhöhe dann über % die Spannung. Bei +6,69% VCore kommt dann ~1,33V im Win raus..
hast du cnq ausgeschaltet im bios? und im win auf höchstleistung?
ich hab jetzt grade im bios auf 1,4v gesetzt und ich bekomme im win korrekte 1,392 mit cpu-z angezeigt.
Außerdem: Nutzt Du diese p-state einstellung im bios (p0-p1-p2-p3)? Die funkt nämlich jetzt. p0 ist der max performance-pstate p1 ist die erste cnq-stufe usw...
ansonsten teste mal mit k10stat, um im win die spannung auf den gewünschten Wert zu setzen, ob der dann übernommen wird und bleibt...
ahso.. XP oder vista?
cnq is aus, os = xp und VID ändern in K10Stat geht nicht bzw wird nicht übernommen. Könnte aber sein, dass es einfach ne alte Version is', die PII nicht unterstützt.
---------- Beitrag hinzugefügt um 08:41 ---------- Vorheriger Beitrag war um 08:35 ----------
PState ist 0, im Bios kann ich die VID auch nicht ändern :eek:
wtf
es ist sicher das bios mit 2009er datum? nicht die 2008er version, die bis montag noch oben stand?
phenom I/II ist bei k10stat wurscht...
ansonsten probier nochmal zu flashen, vielleicht ist da was murks...
Im Moment hab ich das vom 21.1.09 drauf, mit dem neusten und dem 5/05 wars aber das gleiche. Letztens hatte einer das gleiche Problem, weiß leider nicht mehr wer :hmm: Ich macht mal CnQ an..
ja. bei ihm war es die einstellung "energiesparen" im win. Aber du kannst ja nicht mal im bios die vcore verändern???
