[Sammelthread] DFI LANparty UT 790FX M2R / M2RV (AMD 790FX) [1]
Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
IV. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
Weiß nicht mehr genau, ist jedenfalls ne Ramspannung. Das einzige AM2+ Board, bei dem man die im Bios einstellen kann, ist das M2RS mit Modbios, zumindest ist mir sonst keins bekannt.
ok hab das beta-bios vom 01.12. getestet und auch bei mir kein netzwerk (vista64). unter xp sp3 geht es.
irq's werden vergeben an die controller, aber windows installiert beim ersten restart 4 zusätzliche cpu-pci bridges. danach tauchen die netzwerkcontroller als pci-pci bridges ohne ausreichende ressourcen im hw-manager auf...
deinstallieren der zusätzlichen cpu-pci bridges bringt nix, werden beim nächsten start wieder installiert.
ergo funzt noch nicht, abwarten...
Garnichts, einfach Biosupdate und war alles wie vorher.
? das 01.12. beta??
poste mal nen screeny vom hwmanager.. bei mir siehts so aus:
crazy..
ultimate/home/business?
Ultimate. Schonmal Clear CMOS gemacht?
Was ist im Bios mit der CPU Feature "Visualization" gemeint?
Das ist wenn man mit zB Vmware Clients startet die werden beschleunigt dadurch.
Ich weiß nicht, ich bin momentan am Übertakten und eben ist er nur 3 Minuten stabil gelaufen, bei Prime95 und nun schon über eine Stunde nachdem ich es ausgeschaltet habe.
Wobei das natürlich nicht der Grund sein muss das es länger stable ist. Ich hab scho zu oft gedacht das es an manschen Veränderung im Bios lag und dann bei nächsten mal Primen stürtzte er wieder am Anfang ab.
Wenn du keine Virtualisierung nutzt dann lass es aus, auch wenn es nicht dein System stabiler macht.
Ja, aber man kanns ja versuchen. Wenn er gleich wieder abstürtzt, dann stell ich es natürlich wieder auf Enable und geh weiter auf Fehlersuche.
Edit: Die Visualization hat wohl keinen Einfluss auf die Stabilität.
DFI listet Platinen mit Phenom-II-Kompatibilität
........ So hat man bei dem Mainboardhersteller die LANParty-Serie auf Kompatibilität geprüft und entsprechend eine neue BIOS-Version auf die hauseigenen Server gestellt. Unterstützung bieten alle AMD-790FX- bzw. -790-GX-Platinen. Diese umfassen das UT 790FX-M2R, DK 790FX-M2RS, DK 790FXB-M2RS, DK 790FXB-M2RSH, DK 790GX-M2RS und das JR 790GX-M2RS. Da es von DFI keine AMD-Boards mit Nicht-AMD-Chipsätzen gibt, sind somit alle aktuellen LANParty-Boards kompatibel.
http://www.hardwareluxx.de/story.php?id=8866
Läuft bei euch AoD anständig?
Habs länger nicht mehr benutzt, da wenn ich ne spannung (zb. vCore) im bios einstelle, lässt mich AoD Multi oder HTT nicht mehr verändern....
Guten Morgen.
Hab auch gerade mal auf das Final-Bios vom 1.12. geflasht und bei mir will unter Ultimate 32bit das Netzwerk auch nicht mehr...
Hab wie Öse das Resourcenproblem. Hat das schon jemand an DFI gemeldet (vllt auch einer aussem XS-Forum)?
Wenn ja, dann hoffe ich mal das die Jungs von DFI da bald ne Version ohne den Netzwerk-Fehler nachschieben.
Solange muss ich wohl wieder zurückflashen...
Bruder Esau aussm XS weiss Bescheid, der berichtet DFI normalerweise. Allerdings ist er der Meinung, man sollte eh kein Vista benutzen ;)
Hi!
Bin neu hier, lese aber schon ne ganze Zeit mit, da es der beste Thread für das M2RS ist.
Hab die Sapphire Version von dem Teil ...
Hab da auch gleich mal ein Prob:
Habe bei mir nen kleinen 50mm Lüfter auf den Kühlkörper (Heatpipe) der Spawas geschnallt und gute Ergebnisse in Bezug auf die Temps von den Spawas und der SB erziehlt.
Hab ihn auf NB-Fan angeschlossen.
Lässt sich auch prima über den DFI-Smartguardian regeln.
Nur passiert jetzt folgendes!
Der PC geht bei normaler Benutzung (Surfen, normales arbeiten), also fast im Idle öfters einfach aus.
Die Lüfter drehen auf volle Pulle und der PC lässt sich nicht ma mehr durch den Powerbutton ausschalten. Nur reset hilft ... (Postcode habe ich noch nicht nachgeschaut)
Andererseits kann ich ewig Zocken, Benchmarken, Prime laufen lassen, ohne das so etwas passiert.
Stabil ist die Kiste also ...
Hab den Lüfter jetzt mal mit nem 12->7V Adapter an ne Line vom Netzteil gehängt und bisher keine Probs mehr gehabt.
Ist da irgendwas bekannt, dass es Probs mit dem NB-Fan Anschluss gibt?
Wäre für Antworten dankbar.
Gruß,
Archon
Ah, sehr gut.
Dann bin ich mal gespannt wie schnell DFI es umsetzen kann, dass das Netzwerk wieder läuft, denn für den Tipp mit kein Vista benutzen ist es nun schon zu spät :d
Hat ja ausserdem vorher auch geklappt und mittlerweile läuft mein 5000+ BE einwandfrei mit 3,0Ghz, wo er mit vorherigen Biosen instabil lief. Will also nicht mehr zurückflashen, aber wäre schon nett wenn ich Internet haben könnte :P
Edit: Hab gerade noch seine Antwort im XS nachgelesen: Ich benutze die finale Bios-Version unter 32-bit und hab das Problem. Vllt bin ich auch einfach nur zu dämlich, aber bekomme - wie du - die Meldung der fehlenden Resourcen im Gerätemanager...
Schonmal versucht alle Geräte aus dem Gerätemanager zu löschen?
@me[G]a
Ich konnte durch Abschalten der Virtualization noch mal 50MHz mehr rausholen.
Irgendwo meinte ich auch mal gelesen zu haben, dass man bei Overclocking das Feature immer abschalten sollte.
Also die zwei PCI-zu-PCI mit dem hübschen Ausrufezeichen hab ich schon ein paarmal gelöscht, doch nach nem Neustart gehts genau da weiter...
Da ich von den IRQs null Ahnung hab, will ich mich da auch nicht im Bios auslassen, was ja laut Öse sowieso nix bringt.
