[Sammelthread] DFI LANparty UT 790FX M2R / M2RV (AMD 790FX) [1]
Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
IV. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
das bios hab ich auch drauf. istb das beste.. ka warum dfi das wieder runtergenommen hat.
teste mal das neue..
Werd's wahrscheinlich im Laufe des Abends noch testen. Wehe LAN geht immernoch nicht :fresse:
ka will gleich mal *S&M* drüberlaufen lassen xD
ist nicht ganz so gut wie das 05/05. die gmh wollen wieder 2,3v für 4-4-4-8 @ ddr2-1000 wie beim 03/07. mit dem 05/05 gehen auch nur 2,27v (und "früher" sogar nur 2,24v..)
ist aber wurst lasse ich drauf...
Gut möglich dass das Multimeter was anderes anzeigt wenn du mit dem 505er bios 2.3V einstellst als wie beim neuem.
das kann sein noch nicht getestet. aber ausgelesen wird dasselbe und das dürfte nicht direkt was mit dem bios zu tun haben..
kann ich aber nochmal testen.. nur heute nicht mehr ;)
jo bin auch begeistert. man schlägt alarm und es wird sich sofort gekümmert :d
@ wishes: Kannst du mal den x3 mit dem neuen bios auf dem m2r testen? ein xs mitglied hat nur 2 cores mit den neuen bios-versionen...
hier müssen nochmal alle mittesten, damit das bios zeitnah endreife bekommt. es gibt ja nur ne handvoll leute hier und im xs^^
Meint ihr die fixxen, das auch mit der USB Tastatur mal :d ?
Kennt den bug wer?
Wenn ich irgendein USB-Gerät das als massenspeicher fungiert (usb-stick, externe festplatte usw..) beim pcstart angesteckt habe, erkennt er keine Eingaben von meiner usb-Tastatur (G11) bis ich im OS bin. (dh. muss ich die zuerst mal abstecken bevor ich ins bios kann^^)
Den bug hätte ich gern gefixed...
Jupp, der Fehler ist mir früher auch mal aufgefallen... hat mich aber eigentlich nie so gestört ^^
Werd dann auch mal das neueste draufknallen, da ich eventuell auch demnächst Vista installiere :d
wobei mir das mit den gmhs was öse erzählt nicht so gefällt, die laufen grad so schön bei mir mit 1100 Mhz und 2,19v :d
Ja, den bug hab ich. Ich glaube wenn du die USB Tastatur in den ersten USB steckst gehts.
BIOS ist drauf, mir sind keine wirklichen Änderungen aufgefallen... bin grad am testen, ob alles noch läuft :)
Edit: oha, meine Vdimm ist höher... jetzt 2,21V...
Bringt es was den South Bridge Kern und Hyper Transport zu untervolten?
Kann schon sein... dadurch werden vllt NB und die PWMs weniger aufgeheizt und das Board bleibt etwas kühler ^^
Edit: irgendwie könnte der Startpost mal nen Update vertragen... ^_^
ich hab auch nurnoch 2..
Kennt den bug wer?
am besten du registrierst dich auch mal bei xs oder zumindest beim dfi club... dann kannste da direkt mitwirken. aber löppt so ja jetzt auch..
habe übrigens die ram-spannung getestet im vergleich zwischen 505 und DC18. DC18 hat tatsächlich eine um 0,005v niedrigere ramspannung^^ lol und deshalb muss ich jetzt 0,04v mehr geben^^ naja ich hoffe die gmh halten durch bis auch der deneb wieder veraltet ist ;) Oder ich muss die mit cl5 betreiben wenn es nicht mehr geht...
@ wishes: aha :eek: das soll so ja auch nicht...
@ wishes: ist das 2-cores-prob mit dem x3 auch bei dem 12/01/2008 vorhanden??
und ach ja, bitte poste das noch mal im dfi club unter dem alten thread, dass du das getestet und auch festgestellt hast.. dfi scheint die hilfe zu brauchen...
lüppt das lan@vista mit dem neuen bios? kam noch nicht dazu das zu testen, da ich anderweitig beschäftigt bin...
€: bzw. kann ich das nicht testen da das ja bereits bei mir anständig läuft.
Jup, bei mir läuft LAN wieder unter Vista beim Beta Bios.
Zu mehr kann ich nichts sagen, weil ich es gestern Nacht nur schnell geflasht hab, bevor ich ins Bett bin.
Ausserdem macht meine Systemplatte momentan den Adler und ich komm einfach nicht dazu die mal auszutauschen, um festzustellen ob das System wirklich stabil ist...
ja läuft wieder...
Hi!
Wollt noch mal was zu meinem Prob aus dem Post #1585 berichten.
Es lag nicht am Anschluss für den Lüfter.
Irgendwie hatte ich die Spannung für die SB im BIOS auf 1,2V (standard) gestellt.
Laut Smartguardian kommen dabei aber nur 1,1V an.
Hab jetz mal auf 1,3V gestellt (SG 1,19V) und bisher keine Probs mehr gehabt.
Anscheinend hat die SB sich am Undervolting :) gestört und die Kiste dann einfach ausgeschaltet.
Finds aber ein bisschen komisch, weil unter "Optimized Defaults" auch nur 1,2V eingestellt werden.
Schöne Weihnachtsgrüße,
Archon
