Zur Info: Heute wird Arena um 21 Uhr live von Streamern gezockt auf der Twitchcon. Denke ich werde da mal reinschauen. Ihr auch?
Gunsmith 25 gibt ja ordentlich rewards:
Sind um 6 Mios.
welche sind das? Hab den einen für den Raum unten in der Tiefgarage.
Ich laufe meist so ab, Westblock:
Concordia apartment 64 key (Conc 64) is a Key in Escape from Tarkov. A key to the premium apartment inside the Concordia building. In Jackets In Drawers Pockets and bags of Scavs Door to apartment 64 on the second floor of the Concordia building at Streets of Tarkov. Loose loot (Valuables...
escapefromtarkov.fandom.com
Concordia apartment 64 office room key (Conc off.) is a Key in Escape from Tarkov. A key to the office room of the premium apartment inside the Concordia building. In Jackets In Drawers Pockets and bags of Scavs Door to the office in apartment 64 on the second floor of the Concordia building at...
Concordia apartment 63 room key (Conc 63) is a Key in Escape from Tarkov. A key to one of the rooms in apartment 63 in the Concordia building. In Jackets In Drawers Pockets and bags of Scavs Living room door in apartment 63 on the second floor of the Concordia building at Streets of Tarkov...
Die sind direkt nebeneinander. Ein Raum ist da noch offen und ganz gut. Wirst automatisch finden.
Dann den Südblock:
Concordia apartment 34 room key (Conc 34) is a Key in Escape from Tarkov. A key to one of the rooms in apartment 34 inside the Concordia building. In Drawers In Jackets Pockets and bags of Scavs Bedroom door in apartment 34 on the third floor of the Concordia building at Streets of Tarkov. Loose...
Concordia apartment 8 room key (Conc 8) is a Key in Escape from Tarkov. A key to one of the rooms in apartment 8 inside the Concordia building. In Jackets In Drawers Pockets and bags of Scavs Bedroom door in apartment 8 on the third floor of the Concordia building at Streets of Tarkov. It is...
(eher so lala der Raum, aber sowieso anliegend)
Concordia apartment 8 home cinema key (Cinema) is a Key in Escape from Tarkov. A key to the home cinema in apartment 8 in the Concordia building. In Drawers In Jackets Pockets and bags of Scavs Home cinema door in apartment 8 on the third floor of the Concordia building at Streets of Tarkov. It...
Die Loot Spots sind teilweise nicht sichtbar, gerade wenn da nur Stims liegen oder flache / kleine Sachen. Musst dann mal drübergehen und die merken.
Die 6 Räume haben mehr high tier Loot als komplett Customs und die läufst du in unter 10 Min ab. Zudem ist das da auch eher safe da. Sie wurden aber schon was generft, anfangs konntest du da teilweise ohne Witz mehrere Bitcoins alleine schon im ersten finden.
Den security room in der Tiefgarage würde ich danach mitnehmen, ist auch gut.
Die Keys sind nicht einmal teuer, amortisieren sich schon nach der ersten Nutzung, wenn du nicht mega Pech hast.
