[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
Wenn du nich am andern Ende Deutschland wärst, wär ich ja mal vorbei gekommen... :fresse2:
Reizt mich ja mal mit 'nem 352 zu spielen. :d
Mit was Kühlst du denn jetzt? Und was ist alles im Kreislauf?
Hehe ja ist meißtens so das man zu weit auseinandere wohnt :(
Kühlen tue ich das Board,ATI 5850 und den A352 mit nem Feser Xchanger Triple
hmm ein Tripple is da ja schon ein wenig klein bemessen ;)
atm hab ich den Feser 480 für Board und CPU..
gestern noch alles zum laufen gebracht.. jetzt wirst du dir sicher in den Po beißen..
195x21 kompletter large Primerun (und noch mehr) max Temp 59° :d
habs endlich STABIL bekommen..auf gehts ab gehts 200 BCLK
STER187
STER187, wie hast denn den RAM und Uncore laufen bei den 195 BCLK?
die Dommis auf 1,64 @ 1568 (sind eig. 196 BCLK) ergo 3136 UC
will aber eben die 200BCLK um den Ram auf seine 1600 zu haben..
war halt iwi ne Vtt herumscheißerei.... aber das lustige war: gestern eine Stufe Vtt runter und er lief durch (+250) sind bei mir mit MM 1,3 Vtt
STER187
hab halt nicht so ne schöne Perle wie IHR ;)
Ich dacht schon der läuft auf 1950MHz und Uncore auf 3900...
+250mV ist aber schon nicht wenig. Weniger geht nicht? So hoch bist ja mitm UC und RAM eigentlich nicht, oder rennts auf Vollbestückung?
ne nur 6Gig, wissen tu ich dass es viel ist aber beachte bitte das es real 1,3 Vtt sind.
es geht 100% weniger, da die Instabilität ja von der zu HOHEN Vtt kam..
aber da ich 200BCLK machen will lass ich es und teste ob die Vtt dafür reicht..
STER187
Ja von den Temps beiß ich mir in den Popo da hast Recht !
Naja +250mV ist echt viel aber wenn dein Speicherkontroller ned so toll ist kommst halt mit weniger ned zurecht :(
Aber das Ergebnis ist doch schon super !
wooohoo danke, endlich mal Lob für meinen miesen 3520 :d
ja mal gucken, geht sicher auch mit 225 oder vielleicht 200..
aber ich bin gespannt was er für die 200BCLK brauchen wird..
EDIT: mal OT- sitzt Ihr eigentlich auch alle in der Arbeit wie ich ;)
teste nochmal von vorne und lass die VTT niedrig und dann die 200
Wirst schon schaffen denke ich mir, deine CPU ist ja ned so zickig ;)
Dein Xeon ist vlt. eine "Krücke" aber dafür belibt er schön kühl :d und die VCore ist doch echt Nebensache oder ned ?
@OT
Ja bin auch auf Arbeit und vergnüge mich hier denn immo hab ich bisserl Luft.
Ach die 200 schaffst du bestimmt noch locker. Ich vermute mal mit den gleichen Spannungen. :)
Los weiter, wir wollen Ergebnisse sehen. :d
jop werd heut die 200 anschmeißen,
hab zwar nen Screen von gestern Abend aber der ist zu klein (HWluxx resized die Bilder beim abloaden?!)
Vcore war 1,3 für die 196x21 bin aber auf nummer sicher gegangen, da es mir um erster Linie um die Vtt ging.. (wär auch der falsche Run dafür gewesen ;) )
falls er die 200 mit den +250 packt, werd ich noch die Vcore richtig ausloten..
haltet die Bildschirmlupe bereit :d
eigentlich hochgeladen mit 1920x1200
Wie sie sehen, sehen sie nicht. :haha:
Nein klingt doch gut bisher. Mach mal die 200 direkt, das sollte so ja eigentlich laufen.
Und so doll Krücke ist deine CPU nicht. Ich hab schon 2 verbaut, die für 3.9GHz schon über 1.3VCore gebraucht haben.
Obwohl da meiner Meinung nach kein Pin fehlt, sondern der eine Pin "bloß" verbogen ist. Demnach besteht die Möglichkeit, mit feinem Werkzeug, diesen Pin wieder zurück zu biegen.
Nope,in der mitte fehlt einer !
Hab schon mit EVGA Tel. kosten für nen neuen Sockel knapp 100,- !
Muss mir da was überlegen !
Wenn da ein Pin fehlt, wurde dieses Bild so bearbeitet...auf dem Bild ist der Pin jedenfalls verbogen. Der verbogene Pin berührt so ziemlich den anderen Pin rechts.
Für 100-er kriegst aber kein neus, ich würd's tun Artur.;)
Edit:Moin Werner:wink:
Sehe ich genauso!
Guck mal genau nach mit einer Lupe...sollst dich wundern!:d
Das übel Arthur mein Beileid
Versuch den Pin echt mal gerade zu biegen evtl. hilft Dir das ja und dann funzt es wieder.
Hab auch schon ein RIIE gehabt dort waren auch Pins verbogen lief aber einwandfrei.
---------- Beitrag hinzugefügt um 13:06 ---------- Vorheriger Beitrag war um 13:06 ----------
1690MHz und 8-8-8-24 laufen meine bei 1,5V auch, mal sehen was noch drin ist.
Jo gib mal Bescheid was deine noch so machen.
Genau ran da mit Lupe und dem feinsten Schraubenzieher den du auftreiben kannst.
Bevor du 100€ bezahlst, probier erstmal selbst, ob du es wieder hingebogen bekommst (wortwörtlich) :d
würde ne Pinzette empfehlen, und nicht auf einmal biegen sonst bricht er noch ab.. also auf 2 oder 3 Mal
ohohoho noch dazu keine Rechnung, hoffentlich wird das gut ausgehn :d
viel Glück..
