[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
Moin!:wink:
graebens schrieb:
Und hier die Screens was mein Kumpel auf dem CF erreicht hat (Mora2Pro) auf dem Balkon und einmal drinnen.
Hier kannst Du mal sehen, was 10-Phasen Dig.-Spannungsversorgung bedeuten.
Fresh_Thing schrieb:
^^ shice, schon wieder so ein Spruch aus DFI zeiten :fresse:
Moin Artur!:wink:
Jo, auch beim EVGA ist es gar nicht mal so verkehrt mit "weniger ist mehr".;)
DK, war mit Abstand das beste P45-er Board aller Zeiten.:hail:
Moin!:wink:
Moin Artur!:wink:
Das stimmt schon hätte ja auch zum CF gegriffen nur was soll ich machen wenn EVGA mir ein LE schickt :fresse:
Ja da geb ich Dir recht das DK war wesentlich besser als das UT was ich hatte. Obwohl mein Q9650 dort auch gut gelaufen ist ;)
:lol::lol::lol:
Das LE ist ja auch kein schlechtes Board und man kann durch aus damit was erreichen, das CF ist um einiges besser, aber viel zu teuer meiner Meinung nach.;)
Ich seh auch nix obwohl ich extra ne Brille aufgesetzt habe :d
haha :-D imagebanana hat die wohl gelöscht?! seltsam... als ich ins bett bin waren sie noch da :( naja ich war dann bei 200BCLK und 15x Multi... Lief eine Stunde small ohne Probleme durch... Temps -> 60° - werd aber wohl noch nen Lüfter vorne in die Schächte bauen, weil mein TJ07 ist eigentlich schon für die Wakü gemoddet :P
Heut abend test ich den 16er, dann mach ich auch gleich neue Screens :wink:
Ja das ist auch wieder richtig das CF viel zu teuer ist, lohnt sich bei mir sowieso nicht.
LE ist definitiv ein gutes Board und vorallem stabil, hatte ja schon 2 Stck. Bei mir liegt es ja an der Kühlung und nicht am Board. Kann ja nix dafür das die CPU so heizt :d :d :d
Egal bin ja ned drauf aus das ich unbedingt 4Ghz erreiche sondern schau einfach das ich gute Temps hab uns maximal Takt/RAM
Der i7 ist eh schnell genug für die nächsten Jahre.
@graebens
Klar, vielleicht erwischst Du irgendwann ein guten, der nicht so heizt, dann sind auch 4,2GHz @ 24/7 bei vernünftigen Temps drin. Bin gespannt, wie gut, der MO-RA3 mit 4x180-er mein 920-er kühlen kann, mit dem Xigmatek Thor's Hammer waren es "nur" 71°C bei 4,1GHz, wenn die Wakü, es nicht um 10°C toppen kann, werde ich sie zurückschicken.;)
wenn sie da nicht um mehr kühlen wird ;)
da kommst du sicher unter die 60° Marke..
schätze so um die 58-59° :d
STER187
bin gespannt ob ich Punkt genau richtig liege
Vitalij... Was ist wenn du 63-65 grad hast, willst du die dann auch zurück schicken?
Moin Michael!:wink:
Bei 63°C lass ich die Wakü noch drin, bei 65°C bau ich sie wieder aus!:d:fresse2::d
:fp
Na gut aber den Ausbau machst du dann aber selbst. ;) und bevor du testest bin ich aber weg. Will mir dann nicht dein Gemecker anhören :d ;)
:lol::lol:
Brauchst kein Angst zu haben, wird schon schief gehen, wäre bloß schade, wenn die Wakü nur 5°C weniger bringen würde, das wären dann 101,-€ pro 1°C.:rolleyes:
Der Mora3Pro wird Dich überzeugen da kannst Gift drauf nehmen, mein Mora2Pro hat meinen Q9650 der auch ein Hitzkopf war auf sehr sehr kühlen 50°C @ 1,375V gehalten auch wenn man die jetzt ned wirklich mit einander Vergleichen kann. Wart ab und Du wirst Ihn nimmer hergeben wollen. Hab mich damals auch schweren Herzens davon getrennt.
Die WaKü wird das schon gekühlt bekommen. Der MoRa hat ja genug Power. :)
Ich will mein LE wieder habeeeeen.... :fresse2:
Dein Wort in Gottes Ohr, alles anderes, wäre Enttäuschung pur.:wink:
soo, hier wieder die screens, hoffe ihr könnt sie jetzt sehen :-D
im moment läuft jetzt aber schon der 16er multi, ansonsten alles gleich :drool:
Sodala also wenn die Vcore nicht stabil ist ;)
STER187
So ich glaub ich bin auf dem richtigen Weg, das wird dann meine 24/7 Config.
Nun noch bisserl am RAM spielen und dann passt das. Temps sind bisserl hoch aber hier im Raum ist es auch sehr warm :(
Sieht gut aus Manuel. Schau mal ob du den UC vllt noch auf 4000 packst bei gleichem Setting :)
Ster187, auch bei dir schick. 1MHz mehr BCLK vielleicht? Müsste ja genauso laufen, aber hast dann halt richtige 4.2GHz und nicht nur knappe. :d
@ STER187
Bitte das Bild in Post #440 entsprechend verkleinern (max. 900x900px, max. 400KB) :wink:
ich bin grad irgendwie verwirrt... hab jetzt 201 BCLK und 18er Multi damit ich auf meine 3,6ghz komme..
im bios steht memory immernoch auf 2:8 und drunter stehen die 1600mhz... Aber CPU-Z zeigt mir 802 Mhz an (2:8)... bin ich blöd? :confused:
//ahhhh gott wie blöd :d is ja logisch ^^ okay jungs hat sich erledigt
Wollte gerade was schreiben ;)
ja, kannst du dir spaaren, sollte klar sein wenns DDR ist :fresse:
hier noch mein aktueller Stand, damits nicht offtopic wird :P bin bissl überrascht das ich keine vcore erhöhung brauche.. steht immernoch auf VID Settings
//edit
hab jetzt nach etwas über einer Stunde small den custom angeschmissen, mal gespannt wies morgen früh aussieht :)
ja is klar :wink:, war nur mal zum schaun obs sitzt...und es sitzt :d
@ STER187
gehts auch mit Spoiler? sonst kann man den Screen nie gut lesen :(
STER187
