[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
Und wenn ich das jetzt zurück bekomme und es passiert das selbe? Ich kann ja jetzt noch nichtmal nachvollziehen wo der Fehler lag....
Ich würde es erst mal ausbauen und nachschauen wo der defekt liegt.
Schreib den Florian Wendt an und beschreib ihn dann was passiert ist. Man kann ja sehen welcher Spannungswandler es war wenn es daran gelegen hat.
Wo kann ich den erreichen?
hab ja schon ausgebaut, man sieht ja genau welche Spannungswandler abgeraucht ist.
Wow, das Board ist der Oberhammer.
Ich wollte mir zuerst einen 1500€ Rechner bauen und dieses Board kaufen, habe mich aber für einen billigeren Rechner entschieden.
Eine Frage versteh ist bis heute nicht geklärt, ob das Board 4Way SLI oder nur 3Way SLI unterstützt, den bei Geizhals steht 4Way es ist aber nur ein 3Way Bridge mitgeliefert.
Ich habe den Support angeschrieben die haben gesagt nur 3Way, dann war das wohl bei Geizhals nur ein Fehler.
Am meisten gefällt mir Desing, schade das EVGA keine AMD-Boards rausbringt.
ich habe ein relativ unregelmäßiges Problem beim Booten meines Rechners.
Manchmal wird meine Festplatte (glaub nicht das die übern Jordan ist, wär die 3te nacheinander) nicht mehr erkannt, teilweise sogar nach Neustarts (dh. der Rechner lief davor problemlos!)
Hatte sowas schon mal jemand und hat was dagegen machen können?
Robin
Sers Jungens :wink:
kann es sein das 20x200 net so gut läuft wie 19x210 ?!
Denn der 20 multi läuft bei mir fast garnet !
Kann soger sehr gut sein. Ist aber nichts Board-Spezifisches. Es ist relativ bekannt, dass die i7 auf den ungeraden Multis besser laufen.
kann mir vllt jemand sagen, warum mein LE mit dem QPI nicht über 175 gehen will?
gibt es da irgendeinen trick oder welche spannungen muss ich erhöhen?
CPU:i7 965
Vcore:1,305V
QPI PLL Vcore:1,2V
falls ihr noch mehr spannungen braucht müssst ihr mir das eben sagen.
gibts es da nicht programme die das Bios auslesen können? hab da mal was gesehen was so aussah wie von einem Programm ausgelesen...
ich mach aber tzrotzdem gleich mal n paar bildchen.
VTT mal auf +150mV. Wenn du dein DMM da hast mal an den Messpunkten aufm Board nachmessen. Das Board zeigt gern mal eine andere VTT an (auch in Everest), als wirklich anliegt.
Warum gehst du eigentlich nicht über den Multi? Der 965er ist doch offen. Ich meine schon öfter gelesen zu haben, dass die XE nicht so gut gehen mit dem BCLK.
Frag doch mal im 1366 Quatsch-Thread. Die haben da gut Ahnung und können dir bestimmt besser helfen. Hilfreich wäre dann noch, wenn du von allen Spannungen gemessene Werte hast. Also ich weiß so spontan nix weiter. Der macht einfach verdammt früh dicht.
€dit: Prime73... guter Plan. Das hab ich total übersehen... :fresse:
So hier meine Bios Bilder
MCH Strap auf 1600 stellen
Uncore = Ram Takt x 2
OC Recovery hab ich an - ist manchmal ganz hilfreich ;)
VTT mal auf 150% hoch
CPU PLL auf 1,8
QPI PLL kannste auf kleinster Stufe setzten (aber nix auf Auto lassen)
IOH Vcore sollte dicke reichen,kann sein das es auch mit weniger geht
IOH/ICH kanste auch auf kleinster Stufe lassen
ICH vcore kannste auch auf kleinster Stufe lassen
HT Techno. kannste an lassen
QPI Frequency auf 4800 stellen
@DJXaero
weil ich die Vcore soweit ich weiß bei gleichem takt mit höherem blck senken kann und somit auch die temps da ich dn derzeit unter luft fahre...
---------- Beitrag hinzugefügt um 18:34 ---------- Vorheriger Beitrag war um 17:57 ----------
bin mithilfe von Fresh_Thing's tipps bis auf 190 gekommen.
schonmal nicht schlecht^^
Mein Zeil wäre aber 200 was muss ich dafür denn noch anheben?
Moin, ich habe ein Problem mit meinem Board.
Ich habe heute grade mein System auf Wakü umgerüstet, Nun wollte ich es wieder starten, er bootet auch ganz normal, aber wenn windows anfangen müsste zu laden, tut sich nichts mehr. Also die Ladeanzeige zeigt nichts an.
Mein Board zeigt den Code 16 an, was bedeutet: Initalice onboard clock generator.
Was mache ich nun, hat mein Board beim Umbau nen Schaden bekommen oder ist nur irgendwas falsch im Bios eingestellt, hab davor noch ein Bios Reset gemacht.
Ich hoffe ihr könnt mir helfen.
Danke schonmal.
€: un es kommt erstmal noch die windowsmeldung, wo man wählen kann ob normal starten oder oder mit starthilfe, aber bei beidem hängt er sich auf.
Moins,
hab ma ne Frage, ich hab 3x2GB Ram von G.Skill 12800CL6 drinne, hab im BIOS das XMP-Profil eingestellt(1600MHZ, also 800), allerdings zeigt er mir unter Windows 7 in Cpu-Z immer nur nen Takt von 533 an (1067 MHz). Hat da einer ne Idee was da falsch läuft?
Greets,
**Jürgen**
