MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 8x
Fine CPU Clock Ratio...................: +0.0
CPU Frequency .........................: 4000
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 500MHz
PCI Express Frequency (Mhz) ...........: 100Mhz
C.I.A. 2...............................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive........................: 800mv
PCI Express Clock Drive................: 900mv
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 0ps
DRAM Performance Control
Performance Enhance....................: Turbo und Standart getestet
Extreme Memory Profile (X.M.P.)........: auto
(G)MCH Frequency Latch.................: 333
System Memory Multiplier ..............: 2.00B
Memory Frequency (Mhz) ................: 1000Mhz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 18
Advanced Timing Control [Press Enter]
tRRD...................................: 3
tWTR...................................: 3
tWR....................................: 6
tRFC...................................: 54
tRTP...................................: 3
Command Rate (CMD) ....................: 2
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value.....................: auto
tRD Phase0 Adjustmen...................: Auto
tRD Phase1 Adjustment..................: Auto
tRD Phase2 Adjustment .................: Auto
tRD Phase3 Adjustment..................: Auto
Trd2rd(Different Rank).................: Auto
Twr2wr(Different Rank).................: Auto
Twr2rd(Different Rank).................: Auto
Trd2wr(Same/Diff Rank).................: Auto
Dimm1 Clock Skew Control...............: Auto
Dimm2 Clock Skew Control...............: Auto
DDR2 Write Training....................: auto
Channel A Driving Settings [Press Enter]
Driving Strength Profile...............: auto
Data Driving Pull-Up Level.............: Auto
Cmd Driving Pull-Up Level..............: Auto
Ctrl Driving Pull-Up Level.............: Auto
Clk Driving Pull-Up Level..............: Auto
Data Driving Pull-Down Level...........: Auto
Cmd Driving Pull-Down Level............: Auto
Ctrl Driving Pull-Down Level...........: Auto
Clk Driving Pull-Down Level............: Auto
Channel B
Channel B Timings Settings [Press Enter]
DDR2 Write Training....................: Auto
Channel B Driving Settings [Press Enter]
Motherboard Voltage Control:
Loadline Calibration...................: Disabled
CPU Vcore..............................: 1.45
CPU Termination...... 1.200V*..........: 1.30...1,36
CPU PLL...............1.500V*..........: 1.5
CPU Reference.........0.760V*..........: small stable mit
VTT 1,34 bei 0.903 und 0,918
VTT 1,30 bei 0,893 und 0,903
MCH/ICH
MCH Core..............1.100V...........: 1,36..1,40
MCH Reference.........0.760V...........: small stable mit 63% bei den getesten VTT's
MCH/DRAM Ref..........0.900V...........: 1,050
ICH I/O...............1.550V...........: 1,5
ICH Core..............1.100V...........: 1,1
DRAM
DRAM Voltage .........1.800V...........: 2,1
DRAM Termination......0.900V...........: 1,05
Channel A Reference...0.900V...........: 1,05
Channel B Reference...0.900V...........: 1,05
Da 64 bit bisl launisch ist. Ab 500 FSB Quad wird mans sehenAber das OS hat doch gar nichts damit zu tun, sondern ausschliesslich die Hardware. Wie kommt denn da das OS ins Spiel?
Weil der Quad 4 kerne hat und man die Zeit UNGEFÄHR mal 4 nehmen muss....Wieso zeigt dein Taskmanager bei Prime 13 Stunden an?
Also. CPU läuft nun bei 3,6Ghz stabil. Bei 1,25v vid und den Rest auf Standart... Was meint ihr wird da noch ne Menge zu holen sein?
Mal abgesehn davon,d ass das Mobo sowieso am Montag in die RMA geht.
Schönes Ergebnis
Das sind ja dolle Angaben.
Woher soll man wissen um was es sich bei deiner Hardware handelt, oder muß man sich hier im Luxx deine Hardware anhand deiner Beiträge zusammen suchen?
Mal im ernst, mach dir doch nen kurzes Profil fertig. Unten dranhängen oder alternativ bei Sysprofile
Mit ET6 wird nicht übertaktet nur im BIOS. Wenn du 1. Startpost liest steht unten im GTL Thread, dass ET6 von 1.20 VTT geht daher die niedrigen GTL Werte............Wenn ich im Easy Tune die markierten Werte setze läuft FSB 500 über stunden stabil.Wenn ich diese Werte aber ins Bios übertrage,so das die selben werte im Easy Tune angezeigt werden,ist es absolut instabil???Man...dann hab ich die richtigen einstellungen und wenn ich es ins Bios übertragen will geht natürlich wieder gar nichts.Falls jemand ne Idee hat....Wäre echt nett!
CPU Reference müßte demnach im Bios 0,908 sein und MCH Reference 0,903. ???
hi,
das ist das 24/7 system von meinem kumpel.
wir sind damit zufrieden .
http://www.abload.de/img/4000mhzeor6.jpg
gruss benny
nein ist custom run.
