[Sammelthread] Gigabyte GA-EP45[T]-UD3P / UD3R / UD3 (Intel P45) [7]
sorry, what isn das?
[Voltage]
CPU PLL=1.500000 Volts
CPU Termination=1.220000 Volts
CPU Reference=0.800000 Volts
CPU Vcore=1.356250 Volts
DRAM Voltage=2.100000 Volts
DRAM Termination=0.900000 Volts
Channel A Reference=0.900000 Volts
Channel B Reference=0.900000 Volts
MCH Core=1.260000 Volts
MCH/DRAM Reference=0.900000 Volts
MCH Reference=0.800000 Volts
IBT sieht gut aus und Prime large läuft schonmal ein paar minuten :rolleyes:
EDIT: nach 5 minuten FEHLER! :(
Ehm.
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................:
CPU Frequency ...........................:
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................:
CPU Host Frequency (Mhz) ............:
PCI Express Frequency (Mhz) .........:
C.I.A. 2.......................................:
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................:
PCI Express Clock Drive.................:
CPU Clock Skew (ps)....................:
MCH Clock Skew (ps)...................:
DRAM Performance Control
Performance Enhance...................:
Extreme Memory Profile (X.M.P.).....:
(G)MCH Frequency Latch...............:
System Memory Multiplier ..............:
Memory Frequency (Mhz) ..............:
DRAM Timing Selectable ................:
Standard Timing Control
CAS Latency Time........................:
tRCD .........................................:
tRP'...........................................:
tRAS..........................................:
Motherboard Voltage Control:
Loadline Calibration.………................
CPU Vcore….……….........................:
CPU Termination…..... 1.200V*.......:
CPU PLL…………………....1.500V*.......:
CPU Referen.…………....0.760V*.......:
MCH/ICH
MCH Core…………….....1.100V...........:
MCH Reference….…….0.760V...........:
MCH/DRAM Ref.…......0.900V...........:
ICH I/O……………….....1.550V............:
ICH Core…………...……1.100V............:
DRAM
DRAM Voltage ……....1.800V............:
DRAM Termination .…0.900V............:
Channel A Reference 0.900V............:
Channel B Reference 0.900V............:
Füll das mal komplett aus,so ies grade bei dir ist,dann wissen wir mehr.
Also mit F7 ging kein 500FSB,dank der Dimm Skews,braucht für 300FSB +300 und für 500FSB +500 um überhaupt booten zu können!Habe jetzt alle Bios Versionen durch probiert (F4,F6,F7,F8,F9 & F10).F10 ist das einzigste Bios wo ich Ram ohne Dimm Skews mit 1,80V betreiben kann.Mit den Dimm Skews,kann man bzw. ich problemlos bis 480/485 FSB ocen,ab dann gibts sporadische Freezes,mal läuft Large durch,mal nicht,das liegt dann an den Dimm Skews!Einmal lief z.B. 490FSB mit 1,24V MCH durch,beim 2.mal einen Tag später gabs nach 2sec nen Freeze!
Habe jetzt F10 drauf,bin sehr zufrieden,denke nicht das der Ram dadurch schlechter ist,z.B. beim Kumpel (Asus PQ5 Pro) gingen die Low Voltage Dinger von Anfang an problemlos,nur beim UD3P brauchte komischer Weise jeder die Dimm Skews.
Habe ich nicht gewusst das es beim UD3P Dimm Skews braucht.Einglück sind mir diese Skews erspart geblieben beim UD3R und Extreme.Hab schon so öfter Freeze gehabt die ich mit den ich sag mal normalen Skews behandeln konnte.
Dann ist F10 echt ein Treffer.
Habe soeben die 512K (finde ich,ist die magische Schallmauer,da noch nie später ein Freeze bekommen) durchbrochen.Wünscht mir Glück...teste dann noch mal mit weniger MCH/VTT,dann Custom!
Ja wünsche ich dir
Jetzt ohne die Dimm Skews kann man die Freezes auch nachstellen.Es gibt einfach mehr Sinn.
Finde es immer noch etwas schwierig aber hast recht ist schon besser.
Bsp.
F7 mit Skews
1,20/1,24 Freeze 10min
1,22/1,26 Bluescreen
1,24/1,28 Freeze 5min
F10 ohne Skews
1,20/1,24 Freeze 15min
1,20/1,26 Freeze 15min
1,22/1,24 Freeze 1h
1,22/1,26 Bestanden
...hat jetzt mit keinem bestimmten FSB zu tun,nur mal als Bsp...wisst schon was ich meine!
Gut erklärt.
Gruß herm
CPU Clock Ratio ..........................: 8,5
CPU Frequency ...........................: 4,00GHz
Clock Chip Control
CPU Host Clock Control..................: enabled
CPU Host Frequency (Mhz) ............: 471
PCI Express Frequency (Mhz) .........: 100
C.I.A. 2.......................................: Disabled
CPU Clock Drive...........................: 800mV
PCI Express Clock Drive.................: 900mV
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
Performance Enhance...................: standard
Extreme Memory Profile (X.M.P.).....: auto
(G)MCH Frequency Latch...............: auto
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: 942
DRAM Timing Selectable ................: auto
CAS Latency Time........................: 5
tRCD .........................................:5
tRP'...........................................:5
tRAS..........................................:15
Loadline Calibration.………................ enabled (auf disabled läufts noch nichtmal mit 1,4V)
CPU Vcore….……….........................: 1,35625V (ca. 1,32V trotz LLC)
CPU Termination…..... 1.200V*.......: 1,220V
CPU PLL…………………....1.500V*.......: 1,500V
CPU Referen.…………....0.760V*.......: 0,812V
MCH/ICH
MCH Core…………….....1.100V...........: 1,26V
MCH Reference….…….0.760V...........: 0,812V
MCH/DRAM Ref.…......0.900V...........: auto
ICH I/O……………….....1.550V............:1,5
ICH Core…………...……1.100V............:1,1
DRAM
DRAM Voltage ……....1.800V............:2,1
DRAM Termination .…0.900V............:auto
Channel A Reference 0.900V............:auto
Channel B Reference 0.900V............: auto
hab vMCH und VTT etwas angehoben (von 1,2V) -> keine besserung!
Ehm.
Clock Chip Control
MCH/ICH
DRAM
Hi .
das is ne jute Idee
Gruß herm
THE_DOCTOR
Also,das sieht doch schonmal für den Anfang gut aus
Clock Chip Control
Extreme Memory Profile (X.M.P.).....: auto (Disabled)
(G)MCH Frequency Latch...............: auto (333)
System Memory Multiplier ..............: 2.00D (2.00B)
Loadline Calibration.………................ enabled (auf disabled läufts noch nichtmal mit 1,4V) (Disabled)
MCH/ICH
DRAM
So,nun würde ich mal schauen welche Skews bei dir am besten laufen,also oben meine ich diese beiden Sachen.
einfach zb. mal 0/50,50/50 usw. oder andersrum 50/0 usw. und selbst sollte das nicht den gewünschten Erfolg bringen merke di bitte mit welcher Skew Kombi es am besten lief,die Skews sind auf den GB teilweise erfolgs entscheident.
Die VTT,vMCH würde ich erstmal jetzt wirklich ruhen lassen,glaube nicht das es daran liegt bin mit 95% sicher,den Strap hab ich auf 333 gemacht weil das einfach standard ist,keiner hier fährt 400 ist Quatsch,eventuell kannst du ja bei Lust nochmal die Timings manuell einstellen,aber "Auto" reicht für den Anfang.
Nunja jetzt haste erstmal genug Stoff gedenke ich :d
mfg Sascha
also bei mir brauch ich für VTT und vMCH mindestens jeweils 1.26 für 4GHz (evtl. kann ich mit viel getweake um 1 Stufe runtergehen)
läuft aber dafür astrein :)
vMCH glaube ich dir gerne,das kann durchaus möglich sein,aber VFSB das kann ich mir nich so recht vorstellen ich hatte bisher 3 CPU`s und alle haben 1.20v VTT geschafft bei 471 FSB,aber trotz allerdem ist dein Ergebnis gut.
Was ist eigentlich der Unterschied zwischen DS3P und UD3P?
Aufgefallen ist mir, dass mein DS3P kein LLC im Bios hat, dafür aber eine zweite CPU Referenz Spannung..
THE_DOCTOR
Clock Chip Control
MCH/ICH
DRAM
mfg Sascha
ich werds nachmittag probieren, danke!!! ;)
EDIT: was bezwecken die Skews bzw. wofür sind diese gut...Wiki hat mir nicht wirklich weiterhelfen können :rolleyes:
---------- Beitrag hinzugefügt um 15:57 ---------- Vorheriger Beitrag war um 13:19 ----------
also ohne LLC hab ich einen Vdoop von über 0,1V...kann man da was dagegen machen? ich weiß, dass meine cpu mind. 1,31V@LOAD braucht um stabil zu laufen -> aber im bios 1,4V eingestellt (ohne LLC) bringt mir nur 1,29V bei IBT :fresse:
---------- Beitrag hinzugefügt um 16:08 ---------- Vorheriger Beitrag war um 13:19 ----------
hab jetzt mal die vcore (die ja scheinbar das problem darstellt) auf 1,45V (im Bios) gestellt -> sind bei IBT @Load 1,328V und bei Prime 1,360V und im IDLE ca. 1,39-1,4V :fresse:
temperaturen bei IBT max. 72°C, Prime ca. 60°C
...werd versuchen wieder etwas runter zu kommen, schätze mal 1,425 oder 1,4325 ;)
Wieviel V-Core du einstellst ist doch latte hauptsache es läuft,und die Skews naja die bringen halt Stabilität,es kann durchausmöglich sein das das bei dir der weg zum Ziel ist,du wirst 100% Unterschiede bemerken es kann sein je nach Skew Kombo das der Rechner nichmal mehr bootet bis zu large stable,aber stell die V-Core ruig erstmal etwas höher ein,das kann man immernoch machen.
aber intel gibt doch maximale 1,36V an...naja egal, hauptsache es läuft :fresse:
ja unter Last,nicht die im Bios,zudem sollst du ja auch erstmal nur so viel einstellen um den Takt zu garantieren,hab ich das jetzt zu schwer erklärt?xD
Das ist schon richtig, aber die 1.36 sind Load Vcore.
Nicht idle 1.36 und nicht Bios 1.36. Bis ca 1.4(Bios) bist du im absolut grünen Bereich.
Mittlerweile solltest du schon oft genug gehört haben, dass LLC AUS sein soll, also würde ich es dir empfehlen es so zu lassen. Mach dir keine Gedanken über den Vdrop. Der ist so gewollt und der muss auch so sein.
Vor allen klammer dich nicht an einer Vcore Zahl fest, weil je nach Belastung geht die um einiges tiefer. zB hab ich 1.375 Bios was 1.32 im idle ist und unter Belastung Prime95 1.280, IBT 1.264 und sogar bei Linx bis auf 1.248 fallen kann. Entscheidend ist die Stabilität.
Less is more
hab jetzt 1,4375V (bios) für 1,328V-1,344V (IBT) eingestellt, prime läuft gerade...mal schauen :)
von 1,36V@Load bin ich ja noch etwas weg ;)
---------- Beitrag hinzugefügt um 17:07 ---------- Vorheriger Beitrag war um 17:06 ----------
1024k passed - 8k passed - 10k läuft gerade
alles wie vorher, nur kein LLC und Vcore höher:
CPU Vcore….……….........................: 1,4375
MCH/ICH
DRAM
Skews 50, 50 :) (sporadisch eingestellt)
läuft jetzt seit ner guten stunde (prime custom) - sieht gut aus!
Siehst du,Skews bewiren Wunder,ich würde Custom erstmal nur so 1-2 std laufen lassen,und dann die V-Core mit Custom ausprobieren,wenn kerne abbrecen > V-Core hoch.
ich glaube, dass es nur an der Vcore gelegen ist...egal, hauptsäche es läuft ohne extreme spannungen :)
DANKE
EDIT: 1,5 Std. Prime Custom :d
Hallelujah :)
ich wünsch dir, dass es durchlüft
danke!
heute ist mein neuer Q9550 gekommen (L847C427) bei dem scheints echt mit VTT von 1.20 zu laufen, vielleicht sogar weniger.
aber der Oberhammer sind 1,184 Vcore@last bei 4GHz ohne GTLs anzufassen :hail:
THE_DOCTOR
Da es chon über 1 std. bei dir jetzt läuft lote doch mal aus ab wieviel V-Core bei dir im Custom keine kerne mehr abbrechen,wenn man die 1024k,und dann die 8k hinter sich hatt,hatt man meißt die schlimmste Phase überstaden danach brechen wegen V-Core nur noch selten Kerne ab,und wenn dann muss man noch nur einen Wert im Bios hochstellen.
Und mach mal Screen`s :d
war schon eine stufe tiefer und dann ist er ziemlich schnell abgestürzt - jetzt geht`s!
komischerweise war eine stufe mehr Vcore im Bios lt. CPU-Z um über 0,1V (1,312 -> 1,328V) mehr, hat also einen größeren schritt gemacht!
ich lass jetzt noch etwas laufen und erkenne (wenns läuft) dann die settings als stable und belasse sie einfach mal ;)
DANKE!!
hier White: Screen
Achso du hast 1.328v Last grade?.....ja dann passt es doch,so ist sie doch oder fast so bei micro gelaufen oder?
bei prime 1,344v und ibt 1,328v :)
bin soweit zufrieden! :d
Am Anfang aber am meckern das Board wäre doch so schwer etc.^^:motz: ich wll nie wieder was schlechtes über GB lesen :d
bin ja seit dem 965P-DS4 von GB überzeugt, ASUS und MSI sind dagegen :kotz:
Hi, scheint ja ein super Teil zu sein!
Gruß herm
THE_DOCTOR
Jo,für Dualcore stimmt sie ganß gut,aber für QC nicht wirklich leider,daher haben wir für S775. so ziemlich das Optimun was geht;)
