@Felix the Cat
auf dieser
>Grafik< heißt es, daß man auch zum limitierten Übertakten ein P67 Board braucht.
MfG
Heinz
http://www.intel.com/Assets/PDF/prodbrief/324586.pdf
Quote :
Intel H67 Express Chipset also enables overclocking features of unlocked 2nd Intel Core processors.
Quote :
info: Please wait for a site operator to respond.
info: You are now chatting with 'Victor'
xx@xxxx.xxx: Hi,
Victor: Hello. Thank you for using the Intel Customer Support chat service. We are glad to be of service. How can I help you today?
xx@xxxx.xxx: According to
http://www.intel.com/consumer/game/gaming-power.htm, overclocking 2nd Gen Core processors requires a P67 chipset. According to
http://www.intel.com/Assets/PDF/prodbrief/324586.pdf, H67 supports the overclocking features of unlocked 2nd gen Core processors. Which is correct?
xx@xxxx.xxx: I may add that the overview page for the F67 chipset refers to P67.
xx@xxxx.xxx: H67, I mean, not F.
Victor: On the information that I have, both chipset's H and P will support the overclocking on unlocked processors. This will depend on the integration of the chipset and the BIOS.
xx@xxxx.xxx: Very interesting! Nearly all the reviews I have read state that only P67 supports overclocking.
Victor: Currently in our motherboards the P67 chipset motherboard has enabled the overclocking features.
xx@xxxx.xxx: Thankyou. So it is dependent on the motherboard manufacture as to whether an H67 board can overclock or not, I believe.
Victor: Correct.
xx@xxxx.xxx: OK. Now I know what I'll be doing, thankyou.
Victor: You are welcome and thank you for contacting Intel Customer Support.
Victor: Thank you for using chat. We value your suggestions and would appreciate it if you would take a moment to complete our survey. The survey will appear when you click "Close'' to close the chat window. Have a nice day.
Chat transcript with Intel customer service.
Here's my reply from Gigabyte to the overclocking question.
1/14/2011 03:20
Question : Is the H67 motherboard able to overclock the CPU via the clock multiplier?
Model Name : GA-H67MA-UD2H(rev. 1.0)
M/B Rev : 1.0
BIOS Ver : 1
Serial No. :
Purchase Dealer :
VGA Brand : Intel Model : HD3000
CPU Brand : Intel Model : i5 2500K Speed : 3
Operation System : Win XP SP :
Memory Brand : Corsair Type :
Memory Size : 4 Speed : 1333
Power Supply : 400 W
Answer:
You can adjust the CPU Clock Ratio in BIOS. Please refer to the attached user manual for more details.
aber man sollte sich doch nen p67 kaufen wenn man manuell takten will
