[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
in der 1.2.08 Beta kann man z.b keine Powerlimits setzen und sobald man den CO anfäßt, wird die EDC auf 130 abgesenkt. Warum auch immer. Vielleicht kannst du bei Gelegenheit mal gucken ob das immer noch so ist.
Und obacht, bei einigen MSI Boards wird sobald man mit KS rumspielt wohl fixed voltages gesetzt. Nur mit CMOS Clear zu recovern. MSI steckt echt keine Mühe mehr in AM4 :(
Habe jetzt auch die final 1.2.0.8 drauf gemacht und keine Änderung bemerkt. EDC wird beim einschalten vom Curve Optimizer auf 130A gesenkt, wie in der Beta.
Hi dumme frage auf welchen Slot würdet ihre eine 2. M.2 PCIe SSD packen oder ist das egal.
Theoretisch ist das egal. Die oberste Schnittstelle arbeitet über die CPU und die beiden unteren über den X570-Chipsatz. In allen Fällen geht es hoch bis PCIe 4.0 x4. Und das Ganze ohne Lane-Sharing.
Ich hab da ein etwas größeres Problem.Ich habe mein Unify X570 und den 5950x in einen neuen Tower verpflanzt. Alles läuft erst mal so wie es soll dem anschein nach.Das Problem ist das die lüftersteuerung nicht mehr richtig geht im Bios und es gibt keine lüfterregelung wenn die cpu warm wird.Auf der debug led wo immer die Temperatur angezeigt wurde steht danch den ganzen boot codes die 00.
Was habe ich alles versucht:
-mehrfach cmos clear
-neues und altes Bios installiert
-Led Firmware downgrade und über msi cnter aktuallisiert
-Bios Batterie erneuert und 20 min raus
Hat jemand vielleicht eine idee?
@Chris1975
Hi kann denn ein programm wie zb HWinfo oder Aida die Temp der CPU auslesen?
Welche temps werden im Bios im Monitor angezeigt?
Hab's rausgefunden auf der Rückseite ist ein 3x3mm IC der lose Lötstellen hatte und sich weg gebogen hatte.
@Chris1975
Hi das freut ich für dich.
Bei der Problemlösung hätte dir mit Sicherheit keiner helfen können.
Kannst du es selbst wieder anlöten?
Vielleicht find ich hier den nötigen Anstoß.
Seit Upgrade auf das MEG ACE habe ich Stabilitätsprobleme. Programme stürzen ohne Fehlermeldung ab.
Zeitweise liefen meine 4X16GB Corsair Vengeance RGB Pro, zumindest auf 2133Mhz stabil. Hab unterschiedliche Bios Versionen probiert und bei Rückkehr auf das aktuellste lief der RAM plötzlich, wie gesagt nicht mit den gewünschten 3600, aber immerhin.
Da die Riegel aber unterschiedliche Revisionen haben, dachte ich, ich schaffe Abhilfe mit 2x32 GB Corsair Vengeance RGB Pro mit 3200Mhz.
Leider wurde es schlimmer, die Riegel laufen selbst auf 2133Mhz nicht stabil.
Was ich bisher versucht habe:
1. Bios Reset
2. Rambänke / Ram getauscht (aus A2 in B2 und zurück)
3. XMP aktiviert
4. Auf 3200 gestellt
5. Dram Voltage auf 1.35 (vorher 1,2, in HWInfo wird 1.38 angezeigt)
Rest auf Auto.
Zwischendurch immer mal getestet, hat nix gebracht. Prime sowie memtest laufen soweit stabil. Nur sporadisch stürzt bspw. Photoshop, OBS oder spiele ohne Fehlermeldung ab.
Sonstige Hardware :
5900x
RTX 4070Ti
RM 850 Watt
Ich bin echt kurz davor das ganze Geraffel in die Tonne zu kloppen.
Hat jemand ne Idee was ich noch probieren könnte ?
Wie hattest du die SoC-Spannung eingestellt? Auch auf Auto?
Ich hab, außer die Punkte oben, nichts verstellt bzw. dann steht’s wahrscheinlich auf Auto.
Was müsste ich wo einstellen ?
In den Overclocking-Einstellungen im BIOS auf expert stellen und dann runterscrollen. Bei CPU/NB Soc zunächst einmal 1,15 Volt eingeben. Mit dem Aktivieren von XMP wird das Board zwar wahrscheinlich auch diese Spannung mit erhöht haben, aber ausprobieren kann man es ja dennoch mal.
Ah okay.
Aber sollte die Soc Spannung sich dann nicht wieder auf Auto bzw. auf die alten Werte zurücksetzen wenn ich das Bios resete oder das XMP wieder deaktiviere?
Werd ich aber mal testen.
Mit dem BIOS-Reset wird auch diese Spannung wieder auf default gesetzt, stimmt. Wenn dann wieder XMP aktiviert wird, wird sehr wahrscheinlich auch die SoC-Spannung (übertrieben) angehoben. Bis 1,15 Volt ist man da 24/7 im grünen Bereich. Du kannst auch noch einmal probieren, das Verhältnis zwischen dem Infinity-Fabric, dem Speicher-Controller und der DIMMs selbst abzuändern. Diese Einstellungen findest du weiter oben.
Danke dir !
Dann werd ich erstmal nochmals das Bios reseten, xmp laden, 3200 stellen, Fabric dann auf die Hälfte, dram auf 1,35, soc Spannung auf 1.15.
Mal schauen ob es was bringt.
Sehr mühselig das ganze, weil das ganze Testen sehr lange dauert. Da die ganzen Benchmarks ja laufen, aber je nach Datei dann zum Beispiel Photoshop abstürzt. Was ich jedoch provozieren kann, ist der Absturz in OBS, aber das meist auch erst nach ner Stunde oder 2…
Ich würde Ihnen empfehlen, den RAM zu wechseln. Ich hatte anfangs auch massive Probleme mit meinem Unify. Nachdem ich von Corsair auf Crucial umgestiegen bin, lief alles problemlos.
Das hat zunächst wenig zu sagen. Mein X570 Unify betreibe ich mit Corsair-DIMMs und das System läuft stabil.
Stimmt, aber hat er nicht geschrieben, dass der RAM nicht stabil läuft und das bereits mit dem zweiten Satz Corsair-RAM. Also warum nicht das vermeintlich Offensichtliche zuerst angehen?
ein ZenTimings Screenshot wäre auch nicht schlecht, um zu sehen, ob das irgendwas bei den RAM Settings total daneben liegt. 2x32GB 3200Mhz sollte ansich ohne großen Aufwand mit einem 5900X laufen.
Hier mal ein Screenshot vom Ryzen Master und Zentimings.
Hab zum Testen mal auf 2T gestellt, sonst XMP deaktiviert und 3200 sowie 1,35 Volt eingestellt. Läuft so nicht.
GDM auf ON lassen. tRRDS und tRRDL sind eventuell etwas sportlich. Mal mit 5/7 anstatt 4/4 testen. Noch besser wäre ein Foto vom Lot Code auf den RAM Sticks. Daran kann man ableiten, welche ICs verbaut sind und gezielter nach Ungereimtheiten schauen.
Die SoC-Spannung mal anheben. ;)
Gesagt, getan.
Leider bringt das auch nix.
Stell ich die Soc hoch flackert zusätzlich wieder das RGB und Abstürze weiterhin.
Hast du das X570 Ace neu oder gebraucht gekauft?
Weder noch. Hab ich damals von AMD geschenkt bekommen. War aber noch verschweißt. 🙈
Klingt jedenfalls für mich, als hätte das Board ne Macke weg.
Hab ich mir auch schon überlegt.
Wie wahrscheinlich ist es, dass die CPU ne macke hat ?
Sonst ordere ich mir mal ein günstigeres B550.
Soll ja bei den Ryzen 5000 CPUs auch schon vorgekommen sein, dass sie teildefekt sind. Um das jeweils auszuschließen, wäre es deutlich billiger, wenn man zunächst ein anderes Board nimmt.
Verhält es sich mit dem neuen Board ähnlich, kann es eigentlich nur noch die CPU sein.
Ich werde berichten.
Werd mich auch mal mit MSI kurzschließen.
Danke an alle !
