Farme derzeit auch noch auf den Ferdi. Fehlen auch nur noch knapp 300K. WObei ich überlege für den Ferdi ne komplett neue Crew zu nehmen und den Jagdpanther zu behalten.
- TD camouflage bonus after shooting will be removed (SS: currently, when shooting, TD’s don’t lose as much camo as other classes, this will be a nasty nerf especially to very fragile TD’s with big guns, such as the Borsig and WT Panzer IV)
- some light tanks will be buffed (at the very least, MT-25 and VK2801), MT-25 should be buffed approximately to the old T-50-2 level
- tier 4+ light tanks will have their MM tier spread reduced (there will be exceptions for certain vehicles)
- 12 of the worst tanks (statistically) will be buffed and 8 of the best will be nerfed
- Veider states that the camo issue concerns all TD’s, they are too stealthy, this is caused a lot by the TD stealth bonuses
- after the nerf, TD’s without armor will have to keep more distance from their targets
- the list of “good” and “bad” tanks will not be disclosed now
- Aufklärungspanzer Panther will not be rebalanced in 9.1, but later
- Tiger I will be nerfed a bit
- rear-turret VK4502B will not be buffed or nerfed
- improved anti-aliasing will come until the end of the year along with Dx11 support
- Tortoise is slightly OP, but the armor change (nerf) in 9.0 will have some effect, if it’s not enough, it will be nerfed
- FV 215b (183) is apparently doing fine
- rebalance is not based only on winrate
Auch immer fleißig alle Premiumrepairkits/Medkits verkauft die man in letzter Zeit geschenkt bekommen hat?
9.1 Patchnotes von FTR.
Ich weiß nicht wie gut ich da manche Sachen finden soll... . Teilweise ist das allerdings totaler BS (Turtoise Nerf, Tiger Nerf !?).
Die arty onehits bei nem leo pt a sind zu erwarten.soviel zu einem fairen spiel
https://www.youtube.com/watch?v=rsqRYUPRJRs
nettapparently, if you drive your tank onto other tank (or fall on it for example) and the bottom tank gets ammo rack explosion, the turret that will fly off will collide with your tank, throwing it away
das neue Buffed-Heft ist bei mir angekommen, natürlich wieder mit Gratis-Code für World of Tanks / World of Warplanes, den ich nicht brauche. Daher wieder free for all, first come, first serve:
1000 Gold und 7 Tage Premium-Spielzeit für euren Account: A19402-13BFFA-03D4CD
Geht auf buffed.de - Das Portal für Online-Spiele und wählt die World of Tanks-Heftaktion aus. Dann den Code dort eingeben und eure Emailadresse. Daraufhin wird der richtige Code an eure Emailadresse geschickt, den ihr dann in eurem Wargaming-Account unter "Bonuscode eingeben" einlösen könnt. Die Premium-Spielzeit von 7 Tagen beginnt sofort nach dem Einlösen des Codes!
andere frage, wiso haben die den JT aus den historischen rausgenommen?, doch zu historisch mit nem t9 gewessen oder wie?
@RNG Video...
Bei dem Ping und der kurzen aimzeit würde ich auch nix treffen ... die Arty-Shells werden im Berg eingeschlagen sein bei den Positionen/Maps und Artytyp.
@bitmonster
naja mit den tiger 2 ist ja jetzt erst richtig scheisse,
von den m18 wird man gespotet und runtergeschossen ohne das man je was von dennen sieht
