[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Den neuesten VIA Treiber bekommst du HIER
Bei mir macht der VIA Soundchip/Treiber leider Probleme. Ich habe ein ständiges lautes Brummen auf der Leitung. Ohne den VIA Treiber (also nur mit dem Windows Standard Treiber) ist das Brummen weg.
Hat sonst noch jemand dieses Problem?
Habe jetzt letztens W7 Ultimate 64Bit neu aufgesetzt und gar keine Treiber extra installiert (außer Grafikkarte eh klar).
Bei mir funktioniert alles wunderbar und ohne Probleme.
Nochmal ein Frage zum RAM...
Ihr, die 8GB(4x2GB) am laufen habt, mit vom Hersteller vorgesehenen Timings, wie hoch taktet eure CPU & habt ihr C6 aktiviert ?
Wie hoch ist euer BCLK ?
Da ich ja die vom Hersteller vorgegebenen Timings nicht schaffe, teste ich gerade mit 3,6Ghz statt 4Ghz(18x200@2000-8-9-8-24-CR2,C6 an), vielleicht ist ja mein IMC bei 4Ghz nicht in der Lage 4 Module bei diesen Einstellungen zu bewältigen.
Es ist zwar eh bald egal, da das Maximus IV Extreme + 2600K bereits bestellt sind, aber es wurmt mich doch heraus zu finden, woran es liegt...
LinX hat schon über eine Stunde geschafft, mit 7127MB RAM Nutzung.
Scheiß die Wand an, knapp 2h & aus...
also bei mir laufen 16gb 2000er dominator gt's mit standard timings 9-10-9-15-2t bei 1,65v und imc hab ich auf 1,25v. alles mit 4ghtz @ 200 bclk. die rams laufen über xmp profile. per hand kann man die settings aber noch ein wenig besser trimmen. aber das war mir zu fummelig.
Willst du nicht mal deine Systeminfo aktualisieren ?
Womit hast du auf Stabilität getestet ?
Systeminfo hier im Luxx, nicht auf Sysprofile...;)
3-4 Stunden sollten reichen, da läuft irgendwas falsch bei mir.
Ich hätte lieber noch warten & die 1,5v Varianten kaufen sollen...
Also ich habe ebenfalls 4x2GB DIMMs und kann die Timings nicht fahren, weil es auf einer Bank immer Fehler (Memtest) gibt.
Habe dann die Timings einfach um eine Einheit hoch gesetzt und schon lief es einwandfrei (Prime, LinX).
Also ich an deiner Stelle würde mir keinen Kopf machen :)
...und da du ja ohnehin ein neues Board+CPU bekommst würde ich da jetzt keine Zeit mehr investieren ^^
imc auf 1,25v?
ist das bei xmp nicht 1,4v ?
ich hab bei mir alles per hand eingestellt
4x 2gb 2000er domi gt cl8
laufen nun mit 8-9-8-24 1t mit 2000 mhz bei 1,6v
bclk ist 200 *20
hab das erste mal alles stromspar settings an, da bei dem board dann ocing noch geht
Zufrieden stellt mich das nicht...
4x2gb hier siehe sig und keine probleme. timming je nach oc 7-7-7-21 bis 9-9-9-24 funzt einwandfrei.
werde auch blad auf Maximus IV Formula + I7-2600 umsteigen :)
aber bis das board rauskommt wird glaube ich noch paar wochen dauern.
Ein Maximus IV Formula ist doch noch nicht mal angekündigt...
Ich seh da ja nur das Maximus IV EXTREME
sieht gut aus, wäre schon interessant
aber ich würde auf das m4f warten
kurze andere frage
wo bekommt ihr diese backgrouds her?
sieht ja klasse aus
Moin,
da ich nen 875k hab und immer wieder lese, dass das ASUS da wesentlich besser zu Werke geht, wie das EVGA, hab ich mir das ASUS Maximus III Formula geleistet.
Wer hat auch diese CPU und kann mir schon mal Tipps geben?
Will nicht wieder wie beim EVGA Stunden / Tage Pionierarbeit leisten müssen um die Signal-Einstellungen etc. herauszukitzeln..
Danke & Gruß
@sarge
Danke!
Wusste gar nicht dass es für den Sockel 1156 noch neue CPUs gibt ^^
Allerdings sind es ja Clarkdales in 45nm Fertigung, also recht unnötig.
Gerade das gefunden:
Maximus III Formula BIOS 2104 released Jan 17, 2011
1. Improve memory compatibility
2. Improve system stability
3. Update CPU Level up function
4. Update Marvell Option ROM
5. Support new CPUs.
ich hab das neue bios seit 2 tagen darauf. mein system läuft wie vorher. bisher hab keine veränderung gemerkt. also könnt Ihr ruhig updaten :)
Na dann brauch ich ja nicht updaten, wenn es eh wie vorher läuft.
Hab immer noch das 1607 drauf.
Wenn ich schon einen Bios update mache, dann wollte ich auch einen Vorteil davon haben.
ich habe so zusagen alle version probiert. aber wenn man kein unterschied beim bios update bemerkt, heisst es nicht dass das neuere bios nicht gut ist. Asus beseitigt nach und nach die probleme die die user melden. das finde ich sehr kopperativ von asus. bei anderen mainboard hersteller ist leider nicht so.
