[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Ich versuche so viel wie möglich RAM mit LinX auszulasten, also über 7000MB & dann lasse ich es laufen, bis es abschmiert oder durch ist (75 Runs).
Es läuft wohl auf 9-10-9-25-CR2@2000Mhz hinaus, das scheint stabil zu laufen.
Aber gleich muß ich abbrechen & zu meiner Püppy, die wartet...
Also lass dir gesagt sein, dass 25 bzw. 50 runs mehr als ausreichend sind.
Wichtig ist ob Memtest dir Fehler meldet. Erfahrungsgemäß sind LinX,Prime,etc. für den "normalen" Betrieb wenig aussagekräftig, was Stabilität anbelangt. Also wenn LinX 50 runs schafft, Prime > 6 Stunden aushält und Memtest dir keine Fehler zurück gibt hast du an mit Sicherheit grenzende Wahrscheinlichkeit keinerlei Stabilitätsprobleme.
Frohes Fest euch allen !
LaMagra-X, danke dir.
danke... hast du schon neuerungen oder probleme feststellen können? in welcher config betreibst du das system?
Ich hab das Board mit diesem Bios bekommen und kein anderes Bios ausprobiert, daher kann ich keinen Vergleich ziehen.
Betrieben wird es mit einem i5 750er + Luftkühlung, Speicher ist 2x 4GB 1600er Ripjaws 9-9-9-24-1T
OC liege ich aktuell bei ~3,7Ghz mit einem BCLK von 178MHz bei 1,225V (oder so).
Ich möchte ja gerne auf 4Ghz kommen (20x200 / Speicher auf 1600), kriege es aber nicht stabil hin. Irgendwann schmiert er ab und ich hatte schon mehr als ich wollte an V auf den CPU gegeben.
Muß aber auch gestehen das ich bis jetzt kaum was ausgetestet habe. Nur Werte aus dem Forum übernommen und mit Prime / 3Dmark11 auf Stabilität geprüft.
Da muss ich dann noch einmal auf eure Hilfe bauen.....
wie sind denn deine spannungen udn timings?
So, hat ein bisschen gedauert. Gibt es für dieses "bessere" Mainboard nicht ein Tool, welches die Settings genau ausliest?
Wenn ich meinen i5 750 auf 4Ghz stelle, sieht es jedenfalls so aus:
Turbomodus aus, Runtertakten an
Multi 20
BCLK 202
PCIe 101
DRAM 1616
QPI 6471
OC Tuner Turbo
RAM 9-9-9-24 1N
CPU Clock Amplitude usw 4x auf Auto
CPU 1,35v
PLL 1,81525v
IMC 1,25875v
PCH 1,060v
DRAM 1,57675
Spread Spectrum 2x Disable
Memtest läuft (im Dos) sauber (lange getestet)
3D Mark11 schmiert im Physik oder Comined Test ab.
Prime auch relativ zügig
Fehlen Angaben - werden welche nicht benötigt - kann mir jemand helfen? :d
command rate auf 2t mal versucht?
welche und wieviele riegel verbaut?
sosnt mal 1,65v vdimm versuchen
am besten auch mal mehr imc geben 1,40v
bclk mal auf 200 und pcie auf 100
aber doch nicht IMC Spannung :shake:
Damit ist sicher die DIMM Spannung gemeint
Wie war das unter Lukü sollte man nicht mehr als 1,35V IMC geben oder sowas?
ich meinte testweise
man muss sowieso alle spannungen seinem system für 24/7 anpassen
corsair und kingston geben z.b. im xmp profil 1,4v an
und IMC steht ja schon auf 1,25875v
Lief eine Stunde im Prime stabil, dann ist er bei minecraft abgeschmiert :shot:
Möglichkeiten - in welche Richtung sollte ich mal schauen?
SoenniTDI woher haste das Board und die CPu ? ich hatte hier im Forum ein Maximus III Formula mit Bios 2101 + i5 750 verkauft , Das Beta Bios habe ich direkt von Asus per email bekommen weil ich Probleme mit dem OCZ Revodrive hatte , das definitiv nicht fehlerfrei auf dem Board läuft ( auch nicht mit dem Beta Bios ) , eventuell hast du meine Kombi gekauft . Auf dem Board liefen 16GB Gskill RipJaws problemlos , genauso wie auf meinem Board. ( Hatte das MFIII zwei mal ) verkauft hatte ich es an Chrisch http://www.hardwareluxx.de/communit...-12800cl9d-4gbrl-ddr3-95-eur-excl-756636.html
Ja das ist es. Da haben die Teile ja schon eine ordentliche Reise hinter sich *g* :haha:
Läuft auch wirklich schön bis 3,7Ghz - aber da die anderen ja 4Ghz fahren, will man das ja auch :drool:
War es nicht eher so das die revodrive shice generell auf jedem Board Probleme macht xD
Habe mir gestern ein I5-750 bestellt nur fehlt mir im mom nur ein Board. Das Layout von Formula gefällt mir schon recht gut, aber bin noch nicht Schlüssig, ob es auch werden soll.
Der Preis ist schon etwas zu teuer, für meine Ansprüche.
Die CPU soll ja auch nur auf 4 GhZ übertaktet werden. Ist ja auch keine große Sache, nur lohnt sich deswegen die 200€ :stupid:?
Ansonsten hätte ichd as Foxconn oder den MSi mit roten Layout in Ansicht.
Ich weis, das es eigentlich vielleicht nicht hier reingehört :wink:
Das Board ist genial. Zudem hast du eine dedizierte Soundkarte (deren Wert man natürlich nicht überbewerten darf).
Die Soundkarte kenne ich ja schon von meiner Crosshair III.
Reicht absolut aus und bin auch zufrieden. Neu werd ich mir das Board aber trotzdem nicht holen. Vielleicht findet sich ja noch der eine oder andere, der seins loswerden möchte :fresse:
Hallo Leute,
wollte heute mein Maximus in Betrieb nehmen,aber ich könnte kotzen.
Wakü alles verschlaucht angeschlossen usw.
Dann Startbutton und ja Rechner geht an,aber kein Bild,kein Bootvorgang und das wars.
DIe HDD LED aufn Board leuchtet kurz und die CPU LED neben dem 24ATX leuchtet kurz und geht wieder aus.
Danach passiert nichts mehr.
Und Rechner läuft so vor sich hin.
Habe auch schon Bios resett usw. getestet kein erfolg.
Hab dann meine komplette Hardware wieder auf mein altes Board um defekte auszuschließen,und siehe da alles läuft wunderbar auf dem alten Board.
Ich kapiers echt nicht.
Was kann das sein?
Verbaute Hardware
Maximus III Formula
Core i5 750
8GB G.Skill Ripjaws F3-12800CL9D-4GBRL
ATI 5850
Habe auch schon alle Rambänke getestet und auch 2 oder 1 Riegel kein erfolg immer das gleiche.
