[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Ich glaube die Änderungen halten sich schwer in Grenzen. Vielmehr will man die neuen CPUs unterstützen um den Käuferkreis zu erweitern.
eine verbesserung bei dem bios ist zB das erkennen von USB geräte. ich habe einen ASUS DVB-T USB Stick der ab und zu von system nicht erkannt worde. ich musste mehrmals den computer neustarten damit der Stick von win7 erkannt wird. nun seit bios 2104 ist das problem weg. der stick wird rückzug erkannt.
Was für neue CPUs werden eig. unterstützt? Bei der von Asus verlinkten Liste steht bei keiner CPU "since 2104".
Wegen dem neuen BIOS?
jop.
Vorher liefen über 25 runs mit dem 2001er einwandfrei.
Prime läuft jetzt knapp 1,5h. Mal sehen.
1607 bleibt scheinbar das stabilste Bios zum Übertakten.
Bei mir leider nicht, aber in ein paar Tagen ist das auch egal... :coolblue:
Jepp, 2600K(4,5Ghz@1,22vCore) + MIVE :bigok:
Er wird härter^^
Es ist nicht rational - eher emotional. ;)
Ich warte auf Sandy B. EP oder EX
Mehr Dampf & der Spaß, mal wieder was zu verändern.
Brauchen tue ich das nicht, aber wollen...
Ja, so gehts mir bei vielem.
Habe mir jetzt auch ne SSD gegönnt, bereue es aber irgendwie schon wieder, da ich mir mehr erhofft hatte.
Zu dem neuen BIOS:
Also Prime läuft seit heut morgen 11.30 Uhr.
Also ich habe den Kauf meiner SSD nicht bereut, booten in 15s, Programme starten sozusagen sofort, selbst wenn man mehrere gleich hintereinander startet.
Ich habe allerdings nebenbei noch im Internet gesurft...
@mexnhamburg
Also ich kenn die Platte jetzt nicht, aber gegen eine C300 sieht das dürftig aus :)
@All
Also nach über 6 Stunden Prime mit dem neuen BIOS @4GHz (20x200) habe ich abgebrochen.
Nur LinX zickt. Soll mich aber nicht weiter stören.
Naja .... Linx sollte aber nicht zicken.
Das ist anspruchsvoller - gerade was den Lastwechsel (Vdroop) betrifft.
Mag sein. Man hat aber (so zumindest meine Erfahrung) keinerlei Stabilitätsprobleme im Alltag.
Aber unten sind meine Settings. Gibts Optimierungsvorschläge?
Code:
		Extreme Tweaker (LinX (All Mem) 25 Runs - Prime (Custom) 7h
		Version 1607(4GB RAM) - 2001 (8GB RAM) stable
Ai Overclock Tuner  Manual
OC From CPU Level Up  Auto
OC From Memory Level Up  Auto
CPU Ratio Setting  20
> CPU-Konfiguration
	C1E Support  Aktiviert
	Hardware Prefetcher  Aktiviert
	Adjacent Cache Line Prefetcher  Aktiviert
	Max CPUID Value Limit  Deaktiviert
	Intel(R) Virtualization Tech  Aktiviert
	CPU-TM-Funktion  Aktiviert
	Execute-Disable Bit Capability	 Aktiviert
	*Active Processor Core	 All
	A20M	 Deaktiviert
	*Intel(R) SpeedStep(TM) Techno  Aktiviert
	Intel(R) C-State Tech  Aktiviert
	C State package limit setting	C6
BCLK Frequency  200
PCIE Frequency  100
DRAM Frequency	DDR3-1600 MHz
QPI Frequency  6407 MHz
Start auto tuning
OC Tuner  Turbo Profile
> DRAM Timing Control (4 / 8 GB)
	DRAM CAS# Latency  8 / 9
	DRAM RAS# to CAS# Delay  8 / 9
	DRAM RAS# PRE Time  8 / 9
	DRAM RAS# ACT Time  24 / 24
	DRAM Timing Mode  1N /2N
CPU Clock Amplitude				Auto
PCH Clock Amplitude				Auto
CPU Clock Skew					Auto
PCH Clock Skew					Auto
Extreme OV  Deaktiviert
LN2 Mode  Deaktiviert
Full Phase Control  Full Phase
Load-Line Calibration  Aktiviert
CPU Voltage Mode  VID
CPU Voltage  1,3125 (je nach CPU)
CPU PLL Voltage  1,80200
IMC Voltage  1,25875 (je nach RAM)
PCH Voltage  1,08650
DRAM Voltage  1,65625
DRAM Data REF Voltage on CHA	Auto
DRAM CTRL REF Voltage on CHA	Auto
DRAM Data REF Voltage on CHB	Auto
DRAM CTRL REF Voltage on CHB	Auto
Spread Spectrum Control
CPU Spread Spectrum  Deaktiviert
PCIE Spread Spectrum  Auto >>>>> Disabled
> ASUS O.C. Profile
Erweitert
	> Chipsatz
		> Uncore Configuration
			Memory Remap Feature	Aktiviert
	> Onboard-Konfiguration
		J-Micron Controller 01		Deaktiviert
		J-Micron Controller 02		Aktiviert
so far - so good.
Tippe mal auf zu wenig VTT / IMC.. wegen LINX
Wann fängt LINX an zu zicken? nach wieivel runs?
Das letzte mal nach 9 runs glaub...
Habs grad nochmal angeschmissen. Die CPU wird bei mir sehr warm (ca. 75°), weil ich den CPU Lüfter nur bei 80% unter Last betreibe.
Aber sollte für den Prozessor auszuhalten sein,oder?
EDIT:
Sieht nicht gut aus. :-[
LinX Log nach gerade mal 2 runs:
Code:
Intel(R) LINPACK 64-bit data - LinX 0.6.4
Current date/time: Tue Jan 25 10:04:58 2011
CPU frequency:    4.013 GHz
Number of CPUs: 4
Number of threads: 4
Parameters are set to:
Number of tests                             : 1
Number of equations to solve (problem size) : 30452
Leading dimension of array                  : 30456
Number of trials to run                     : 25
Data alignment value (in Kbytes)            : 4
Maximum memory requested that can be used = 3125214816, at the size = 30452
============= Timing linear equation system solver =================
Size   LDA    Align. Time(s)    GFlops   Residual     Residual(norm)
30452  30456  4      324.788    57.9694  8.797169e-010 3.375853e-002
30452  30456  4      321.639    58.5371  1.907359e-006 7.319357e+001
Da sieht man z.B. das LINX nicht ohne ist und durch den Lastwechsel die Temps auch mehr abgehen.
Ich verstehe wenn man sagt, 8 Stunden Prime = stabil. Aber oft kommt es dann vor, dass der Rechner dann in Windows plötzlich abschmiert, obwohl man grad nur bei Luxx gesurft hat.
Kannst mal probieren Vcore und VTT leicht zu erhöhen..
PLL zu senken,
CPU skew zu nutzen
LLC mal disablen
aber nicht alles zusammen, step by step
IMC ist VTT. "internal memory controller"
PLL ist Phase Locked Loop, dieser Wert ist sehr empfindlich, meist ist eine Erhöhung schlecht, manchmal hilft es den Wert zu senken beim overclocking.
Okay. Gute das ich gefragt habe :p
Wenn ich die IMC erhöhe steigen die Temps sehr stark an. Ich verweise immer wieder auf Intel Spec von max. 1,21 ^^
Aber danke für die Tipps. Werde mich dann heute Abend dran machen.
Hätt ichs bloß gelassen das neue BIOS draufzuspielen. Wenn alle Stricke reißen mache ich eben ein Downgrade.
was ja nur für die erste Charge der I7 galt,... mittlerweile und auch schon länger ist das Limit bei 1,4V für VTT / IMC
Ist es problematisch wenn ich die IMC mit ASUS TurboEvo ändere?
Ich komm grad nur remote auf den PC :)
