[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Hi.
Ich kenne das Problem. Ich hatte das bei einem Gigabyte P55 Board. Habe ewig gerätselt, kam aber dann drauf.
Problem ist das Sockelsystem bzw. die Pins des Mainboards. Beim Einrasten der CPU kann es vorkommen, dass sich ein Pin in die falsche Richtung dreht und somit Kontakt mit der falschen Kontaktfläsche bekommen. Folge ist z.B. genau dieses Verhalten mit dem Arbeitsspeicher.
Also: Nimm deine CPU runter und schau dir die Pins auf dem Mainboard und die Pin-Abdrücke auf der CPU genau an. Wenn dir ohnehin gleich auffällt dass ein PIN verbogen ist hast du das Problem gefunden. Dann einfach ganz vorsichtig wieder in Position bringen (am besten mit einem ganz kleinen Uhrenmacherschraubenzieher) und weg ist der Spuck.
Ansonsten musst du halt sehr genau hinschauen, ob die Pin-Abdrücke alle geich aussehen und ob die Pins alle eine gleichmäßige Biegung aufweisen.
Das Sockelsystem ist ziemlicher Käse leider.
Hoffe das hilft dir.
Grüße
Hallo.
Ich habe seit heute ein seltsames Problem, auf RAM Bank 2(die erste Rote) wird scheinbar kein Modul mehr erkannt...
Im Bios werden nur noch 2GB angezeigt, obwohl 4GB eingebaut sind.
Unter Windows wiederum werden 4GB angezeigt aber in Klammern steht dahinter, das nur 2GB verwendbar sind.
Was ist das für'n Mist, ist das Board hinüber ?
Habe auch schon alles hin & her gesteckt, Module einzeln getestet, sie funktionieren.
Auch wenn ich 8GB stecke, werden nur 6GB erkannt.
Ich hoffe, jemand hat nützliche Tipps für mich.
Gruß Daniel
PS. Erledigt, CPU aus & wieder eingebaut, läuft...
Hatte das auch auf einmal,auf der Seite Xbitlabs war es das(nicht aktivierte) Remaping Feature.Bei mir hat es schon gereicht den Kühler etwas zu lösen.
Richtig - Oft hat dies mit einem zu hohen oder zu niedrigen Anpressdruck der CPU auf dem Sockel zu tun.
War bei meinem EVGA Board auch so..
hy leute, hab mir das board jetzt auch mal gegönnt... mit einem i5 760 und 2 8gb corsair dominator gt 2000er kits. hat schon jemand erfahrung wie es mit 16gb vollbestückung läuft?
hab eigentlich hier noch keinen gesehen,der mit 16GB rumhantiert,weils im Grunde eh unedig ist.
Aber wennst sie drinnen hast,berichte bitte mal.
Also ich habe 16 GB G.Skill RipJaws drauf und läuft einwandfrei ohne Spannungserhöhung
1.5 Volt Standard Timings 9,9,9,24,2T und 2:8 Teiler ,sind denn deine Dominator für das Board freigegeben ???
naja offiziell sind nur die 1866er dominator unterstützt. von den 2000er modulen sind eh nur sehr wenige vertreten. try n error.... mal schauen was geht wenn ich alle teile da habe.
wie wahrscheinlich sind denn 4GHz Takt auf dem Board mit Lukü?
Seeeehr wahrscheinlich.
Schau dir doch mal die ganzen Signaturen und Systeminfos an. Da ist ja kaum einer dabei der keine 4GHz fährt :)
Ja aber die meisten haben Wakü...das ist mein Problem.
Ich hab auch keine Wakü.
Hol dir den Zalman CNPS9900 MAX. Damit kannst du garantiert 4GHz+ fahren. Ich hab den CNPS9900 und fahre ebenfalls 4GHz mit einem Core i5. Bei LinX+Furmark wird die CPU ca. knapp über 70° warm. In Spielen und bei anderen Anwendungen langweilt sich die CPU aber sehr..da gehen die Temps nie über 50°.
Grüße
Hallo leute,
bekomme heute ein Maximus III Formula
Könnt ihr mir sagen welches im mom das beste und stabilste Bios ist.
Betrieben wird es mit nem core i5 750 der die 4ghz packen soll.
Ich glaube das dürfte dann wohl das 1607 sein oder was meinen die anderen?
ok hört sich schon mal gut an.
Und kann mir evtl jemand bios settings für 4ghz mit nem core i5 750 posten?
Muss jetzt LLC an oder aus sein?
Wäre nett wenn jemand was sagen könnte
les Dir doch ein wenig den Thread durch,da wirst Du verschiedene interessante Dinge erfahren,und irgendwo(bin jetzt auch zu faul zum gucken)stehen dann komplette Bios einstellungen,die alle wichtige einstellungen beinhalten.
Das 1607 und das 2001 laufen bei mir beide gleich stabil. Alle dazwischen waren in meinem Fall OC unfreundlich.
MfG
EDIT:
Meine Settings mit genau dieser Config stehen mehrmals hier im Thread...also Augen auf ;)
MfG
EDIT:
Ja hab ich auch schon gefunden und ausgedruckt nach dem ich gestern den ganzen letzten Fred durch hatte.
Ich will das ganze ohne Turbo und Stromspahrfunktion.
Und deine Settings sind ja mit Turbo usw ;) oder hab ich da was falsch verstanden?
Und kann ich dann gleich bedenklos aufs 2001 gehen?
Da hast du was gänzlich falsch verstanden. Der Turbo wird ohnehin ab einem bestimmten Taktlimit deaktivert (im BIOS).
Zudem kommt es noch ganz darauf an, welchen RAM-Takt du fahren möchtest.
Und warum willst du keine Stromsparfunktion!?Was bringts dir wenn die Kiste im Idle mit 4GHz taktet?! ^^
ja hast du auch wieder recht ;)
Also ich habe 8GB G.Skill Ripjaws F3-12800 mit 9-9-9-24 1,5V 1600mhz
Also passt. Hau meine Settings rein, dann hast du IST und hoffentlich stabile 4GHz :)
Danach kannst du ja mit den Spannungen runter und testen obs stabil läuft.
Wie kühlst du?
Hat jemand von euch von 4GB RAM auf 8GB aufgerüstet, also von 2 Modulen auf 4 ?
Bei mir will es nicht, ich glaube fast, das ein Paar kaputt ist, bin nun schon fast eine Woche am testen, aber es ist nicht stabil zu bekommen.
Es sind diese hier : CMT4GX3M2A2133C9 , das erste Paar, das ich gekauft habe lief prima, aber zusammen mit dem 2ten stürzt es nur ab, auch mit entspannten Timings.
Bin jetzt dabei, sie einzeln zu testen, evt. muß das 2te Kit zurück.
Für gute Tips wäre ich sehr dankbar.
Gruß Daniel
Nicht mal entspannung der Timings ?
nein wieso auch
stell doch ganz einfach die Timings ein die vom hersteller angegeben sind
Und ob der speicher ok kannste doch testen.
Nimm halt mal iimmer nur ein 4gb paar und schau was dann passiert
Der Hersteller hat die Timings aber nur für ein Paar, also 4GB vorgesehen.
Aber mein Verdacht erhärtet sich gerade, das neue Kit ist mit LinX in Run 15 abgeschmiert, mit gleichen Einstellungen & dem minimal älteren Kit, bin ich gerade bei Run38 & alles ist prima.
Das neuere Kit wird wohl einen wech haben...
also es is doch scheißegal ob du 4 oder 8gb hast.
Die Timings der riegel bleiben doch gleich.
Wie gesagt mal alle Module einzeln testen
Gruß Daniel
Ich hatte doch dasselbe Problem. 1 Kit (2x2GB) lief einwandfrei auf A1+B1. Aber bei Vollbestückung mit einem weiteren Kit gab es immer Fehler auf A2 (hoffe ich verwechsel die Banknummern jetzt nicht :p).
Habe dann einfach die Timings von 8-8-8-24 (1T) auf 9-9-9-24 (1T) gesetzt und gut war.
Performancetechnisch macht das nichts aus.
EDIT:
Das stimmt definitiv nicht. Der Hersteller gibt die Timings immer im Kit an. Also z.B. 2x2GB DIMMs. Wenn du also 4x2GB DIMMs mit "versprochenen" Timings haben möchtest, musst du immer ein Kit kaufen (also z.B. 4x2GB oder 2x4GB). Der Hersteller gibt keine Timing-Garantie auf 2 gleiche Kits im simultanen Betrieb wie in meinem Fall mit den Dominator-Kits.
MfG
Ich habe nun beide Kits einzeln mit erhöhten Spannungen(1,21vCore,1,3vIMC,1,66vRAM,1,11vPCH) getestet, die sind in Ordnung, jetzt müssen sie nur noch zusammen laufen & dann die Spannungen wieder so weit wie möglich drücken...
