[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Ich verweise immer wieder gerne auf den genialen Post von Coolsys KLICK
Da steht im Grunde alles drin, was man für das Board zum OCen benötigt. Unter anderem auch die Stromsparfunktionen des Boards.
Ich hatte doch dasselbe Problem. 1 Kit (2x2GB) lief einwandfrei auf A1+B1. Aber bei Vollbestückung mit einem weiteren Kit gab es immer Fehler auf A2 (hoffe ich verwechsel die Banknummern jetzt nicht :p).
Habe dann einfach die Timings von 8-8-8-24 (1T) auf 9-9-9-24 (1T) gesetzt und gut war.
Performancetechnisch macht das nichts aus.
EDIT:
Das stimmt definitiv nicht. Der Hersteller gibt die Timings immer im Kit an. Also z.B. 2x2GB DIMMs. Wenn du also 4x2GB DIMMs mit "versprochenen" Timings haben möchtest, musst du immer ein Kit kaufen (also z.B. 4x2GB oder 2x4GB). Der Hersteller gibt keine Timing-Garantie auf 2 gleiche Kits im simultanen Betrieb wie in meinem Fall mit den Dominator-Kits.
MfG
Also ich weis nicht.
Ich hatte bis gestern 4gb von den Ripjaws.
Habe gestern weitere 4 dazugesteckt und absolut keine Probleme.
und betreibe sie mit genau den Settings des Herstellers
LaMagra
kann ich jetzt gleich bedenklos das 2001 auf mein Maximus flashen?
Und welche Sata Ports sollte ich für die HDD nehmen?
Die roten sollen ja so ne Game funktion haben
Wie gesagt, es funktioniert i.d.R..aber der Hersteller garantiert es dir nicht. Darum gings mir.
LaMagra
Ja kannst du.
Nimm auf jeden Fall die SATA Ports des Intel Controllers.
Lass die roten (unten) bloß weg. Der JMicron Controller hat auf so einem Board keine Daseinsberechtigung.
Also HDDs an den Intel Controller (6 SATA Ports) und die optischen Laufwerke an die ODD Ports.
Grüße
alles klar werds dann so machen.ich hoffe das ich übermorgen mit dem umbau beginnen kann
Irgendwie scheine ich die Sch... nicht hinzubekommen, 8GB Domi GT wollen nicht zusammen laufen, defekt ist aber keins von den beiden Kits.
Vielleicht liegts ja auch am Bios, habe nämlich für die neuen RAM's das 2001 geflasht, das 1607 war meiner Meinung nach eh das bessere, wenn der jetzige LinX Run wieder fehlschlägt, werde ich das 1607 wieder draufflashen.
Ich hab die 2133er...
Ja, ist auch nach etwa 30 LinX Runs abgeschmiert.
2000Mhz 9-10-9-25-CR2, gerade wieder abgeschmiert, 1600Mhz habe ich auch schon ohne Erfolg versucht.
Nun ist das 1607 dran...
Was du auf jeden Fall machen solltest ist Memtest.
Erst vollbestücken, schauen ob Fehler gibt. Wenn ja, einen nach dem anderen rausnehmen und eine fehlerhafte Bank ausfindig machen.
Und ich würde mal gerade Timings fahren...also 8-8-8 / 9-9-9 / etc.
Die Speicher sind doch aber für 9-10-9-24-2T@2133Mhz vorgesehen, warum sollte ich die "gerade" fahren ?
Habe ich übrigens auch schon versucht, führt nur zu noch schnellerem Absturz...
Hast du nun Memtests gemacht und die fehlerhafte Bank (oder auch Bänke ausfindig) machen können?
Nein, so weit bin ich noch nicht, die LinX Tests mit 8GB dauern doch immer so endlos lange...
Ganz schön langweilig :xmas:
Noch eine Frage an die 8GB Nutzer, habt ihr C-STATE C6 aktiviert ?
Heißt das ja ? (aktiviert)
Dieses Drecksbios 2001 scheint der Übeltäter gewesen zu sein, so weit wie jetzt mit dem 1607 bin ich noch nie gekommen...
Ich bin jetzt bei 3 Stunden, Hammer !
Kann ich wohl alles gleich mal schärfer stellen...
so bin jetzt auch stolzer besitzer des max II formula ;)
läuft bis jetzt mit dem 2001er bios stabil in kombination mit meinem i5 760 und 16gb dominator gt 2000er ram. setze mri jetzt noch ein paar testsysteme auf und morgen gehts mal ans gesten. auf anhieb bin ich auch schon problemlos auf 4ghz gekommen. will das nur ein wenig altagstauglicher machen von den volt settings her. was mir bis dato nur arg aufstößt ist, das die x-fi ja wie schon bekannt nur im oberstem slot läuft und unten nicht einmal erkannt wird. aber naja mal schauen was da noch so kommt.
Wie kann das nur so unterschiedlich sein, mit den Domi GT's...
Hast du schon anständig auf Stabilität getestet ?
@ Tobi
Glückwunsch kommt vielleicht zu früh, mit 8-9-8-24-CR2 wird es nix...
Achso, dein Wallpaper :
ne leider noch nciht. stabi tests mache ich mrogen.. da hab ich genug zeit :d
@tobias: 16gb zwecks virtualisierungs und 3d konstuktionsarbeiten....
ausserdem wars mit knapp 400€ auch billid
@ Tobi
danke!
wirst schon stabil bekommen, sonst gehn wir einfach nochmal alles settings durch
hab auch ne weile gebraucht das wirklich stable zu bekommen
ok kann ich verstehn, dafür hab ich aber ne zweite kiste :)
so wünsch euch merry x-mas :d
Also ich hatte sowohl mit dem 1607 als auch mit dem 2001 Probleme mit den 8er Timings.
Aber darf man mal fragen, wie genau die testest?
LinX 25 runs?
Prime? Wenn ja, wie lange?
Grüße
@ LaMagra-X
Meinst du mich ?
