VwCaddyGolf1
Na wer kennt es?
So hätte Crysis von Anfang an aussehen müssen. Einfach nur traumhaft.
Hm, seltsam. l@mer und andere User berichten von stabilen FPS im 40er Bereich. Da stimmt was nicht, poste doch mal die autoexec.cfg die Du grad verwendest hier rein, ich schau mir das mal an![]()
r_ColorGrading = 1
r_DepthOfField = 2 (wichtig für´s DoF)
r_MotionBlur = 0
r_HDRlevel = 1.30 (4 ist zuviel)
e_particles_lod = 0.75 (je höher der Wert, desto mehr FPS verlierst Du)
e_detail_materials_view_dist_xy = 8192
e_detail_materials_view_dist_z = 512
r_detaildistance=15 (wie kommst Du auf 150?)
e_view_dist_ratio = (solltest Deinen Wert von 200 nochmal überdenken, alles über 100 zieht an den Frames)
[LSD]Timewarp´s 82 autoexec.cfg
con_restricted = 0
r_width=1280
r_height=1024
r_displayinfo = 0
r_VSync=1
d3d9_TripleBuffering=1
cl_hitblur=0
cl_hitshake=0
i_noweaponlimit=1
i_giveallitems
i_unlimitedammo=1
g_godmode=1
e_screenshot_width = 4096
e_screenshot_height = 3072
e_screenshot_quality = 100
e_screenshot_file_format = jpg
; Post Processing
r_ColorGrading = 1
r_DepthOfField = 2
r_MotionBlur = 0
; Shaders and Light
r_EyeAdaptationBase=0.25
r_SSAO = 1
r_SSAO_amount = 1
r_SSAO_blur = 4
r_SSAO_blurriness = 1
r_SSAO_darkening = 0.67
r_SSAO_quality = 2
r_SSAO_radius = 1.6
r_HDRlevel=1.30
r_hdrbrightthreshold=30
r_hdrbrightoffset=30
r_Usepom = 1
r_sunshafts = 1
r_Beams=3
r_BeamsDistFactor = 0.01
r_BeamsMaxSlices=350
; Shadows
e_shadows = 1
r_ShadowsMaskResolution=0
e_shadows_on_alpha_blended=1
e_shadows_from_terrain_in_all_lods = 0
e_shadows_cast_view_dist_ratio = 10
e_shadows_max_texture_size=1024
r_ShadowBlur=3
r_ShadowJittering=1
; Object Detail
e_obj_quality=4
ca_useDecals=1
e_decals_allow_game_decals=1
e_decals_life_time_scale=3
i_rejecteffects=1
sys_flash_curve_tess_error=1
e_view_dist_ratio=80
e_max_view_dst_spec_lerp=1
es_DebrisLifetimeScale=1
e_cbuffer_resolution=256
e_dissolve=1
ca_DrawFaceAttachments=1
ca_AttachmentCullingRation=200
e_terrain_occlusion_culling = 1
e_terrain_occlusion_culling_max_dist=500
e_terrain_occlusion_culling_max_steps=500
e_terrain_occlusion_culling_precision=0.25
e_terrain_occlusion_culling_precision_dist_ratio=5
e_terrain_occlusion_culling_version = 0
; Vegetation
e_foliage_wind_activation_dist = 20
es_DebrisLifetimeScale = 1
r_DetailNumLayers = 2
r_VegetationSpritesTexRes = 128
r_DynTexAtlasSpritesMaxSize = 32
r_TexAtlasSize = 2048
e_vegetation_bending = 2
e_vegetation_min_size=0
e_proc_vegetation=1
e_vegetation_use_terrain_color=0
; Particles
e_particles_quality=4
e_water_ocean_soft_particles= 1
e_particles_max_emitter_draw_screen = 7000
e_particles_object_collisions=1
r_UseSoftParticles = 1
e_particles_thread=1
; Water
r_WaterReflectionsQuality = 4
r_WaterUpdateDistance = 0.2
r_WaterUpdateFactor=0.01
r_WaterCaustics=1
r_WaterRefractions=1
r_WaterReflections=1
r_WaterReflectionsMGPU=1
r_WaterReflectionsMinVisiblePixelsUpdate=0.001
r_waterReflectionsMinVisUpdateDistanceMul=10
r_waterReflectionsMinVisUpdateFactorMul=20
r_waterReflectionsUseMinOffset=1
r_waterupdatechange=0.01
r_waterupdatetimemax=0.1
r_WaterGodRays = 1
e_water_volumes=1
e_water_waves=0
e_water_waves_tesselation_amount=100
e_water_ocean_bottom=1
e_water_ocean_fft=1
e_water_tesselation_amount = 12
e_water_tesselation_swath_width=100
q_ShaderWater=3
e_phys_ocean_cell = 0.1
e_phys_foliage=2
; Misc
e_max_entity_lights = 12
g_battleDust_enable = 1
g_breakage_particles_limit =500
g_ragdollDistance = 99
g_ragdollMinTime = 99
g_ragdollunseentime=99
e_terrain_ao=1
e_terrain_normal_map=1
p_max_substeps_large_group=5
p_num_bodies_large_group=100
; LODs
e_vegetation_sprites_distance_custom_ratio_min = 1
e_vegetation_sprites_distance_ratio=1.5
e_cull_veg_activation = 70
e_view_dist_ratio_vegetation = 60
e_particles_lod=.75
es_MaxPhysDist=300
es_MaxPhysDistInvisible=25
e_terrain_lod_ratio=1.3
e_view_dist_ratio_detail=40
e_lod_ratio=8
e_lod_min=0
e_lod_max=0.5
e_lods=0
e_detail_materials_view_dist_xy=8192
e_detail_materials_view_dist_z=512
r_DetailDistance=15
q_quality=3
; FPS Gain commands + Bonus
sys_physics_CPU=3
r_UseEdgeAA=2
r_TerrainAO=7
r_TerrainAO_FadeDist=6
r_GeomInstancing=1
e_vegetation_static_instancing=0
e_gsm_cache_lod_offset=2
e_gsm_lods_num = 5
e_gsm_range = 3
e_gsm_cache = 0
e_ram_maps = 1
e_dissolve = 1
cl_fov=60
cl_hud=0
r_TexMaxAnisotropy=16
r_Texture_Anisotropic_Level=16
r_TexturesStreaming=0
Config Loaded!
damals gabs grad mal den Q6600 frisch und die 8800 GTX, das hätte kein Schwein spielen können![]()
