@Fresh_Thing: Hier sind meine Settings. Das muss doch ein Bug sein, wenn die Einstellungen vorher stabil waren. Und nicht nur diese Einstellungen...
>CPU Feature:
Thermal Management Control.......... - Disabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Disabled
Virtualization Technology........... - Disabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Normal
Enhance Addressing.................. - Normal
T2 Dispatch......................... - Disabled
>Clock Setting Fine Delay Press Enter:
DLL And RCOMP Settings.............. - By User
Ch1 Dram Defaul Skew................ - Model 3
Ch2 Dram Defaul Skew................ - Model 3
RCOMP Settings...................... - Model 1
Fine Delay Step Degree.............. - 140ps
Ch1 Clock Crossing Setting.......... - More Relaxed
DIMM1 Clock Fine Delay.............. - Current[2396ps]
DIMM2 Clock Fine Delay.............. - Current[2396ps]
Ch1 Control0 Fine Delay............. - Current[268ps]
Ch1 Control1 Fine Delay............. - Current[268ps]
Ch1 Control2 Fine Delay............. - Current[268ps]
Ch1 Control3 Fine Delay............. - Current[268ps]
Ch1 Command Fine Delay.............. - Current[394ps]
Ch2 Clock Crossing Setting.......... - More Relaxed
DIMM3 Clock Fine Delay.............. - Current[2066ps]
DIMM4 Clock Fine Delay.............. - Current[2066ps]
Ch2 Control0 Fine Delay............. - Current[48ps]
Ch2 Control1 Fine Delay............. - Current[48ps]
Ch2 Control2 Fine Delay............. - Current[48ps]
Ch2 Control3 Fine Delay............. - Current[48ps]
Ch2 Command Fine Delay.............. - Current[394ps]
Ch1 Ch2 Common Clock Setting........ - More Relaxed
Ch1 RDCAS GNT-Chip Delay............ - Auto
Ch1 WRCAS GNT-Chip Delay............ - Auto
Ch1 Command To CS Delay............. - Auto
Ch2 RDCAS GNT-Chip Delay............ - Auto
Ch2 WRCAS GNT-Chip Delay............ - Auto
Ch2 Command To CS Delay............. - Auto
Flex Memory Mode..................... - Auto
CAS Latency Time (tCL)............... - 5
RAS# to CAS# Delay (tRCD)............ - 5
RAS# Precharge (tRP)................. - 5
Precharge Delay (tRAS)............... - 18
All Precharge to Act................. - 6
REF to ACT Delay (tRFC).............. - 54
Performance Level.................... - 14
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In........... - Auto
Channel 1 Phase 1 Pull-In........... - Auto
Channel 1 Phase 2 Pull-In........... - Auto
Channel 1 Phase 3 Pull-In........... - Auto
Channel 1 Phase 4 Pull-In........... - Auto
Channel 2 Phase 0 Pull-In........... - Auto
Channel 2 Phase 1 Pull-In........... - Auto
Channel 2 Phase 2 Pull-In........... - Auto
Channel 2 Phase 3 Pull-In........... - Auto
Channel 2 Phase 4 Pull-In........... - Auto
Write to PRE Delay (tWR)............ - 14
Rank Write to Read (tWTR)........... - 11
ACT to ACT Delay (tRRD)............. - 3
Read to Write Delay (tRDWR)......... - Auto
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - 4
ALL PRE to Refresh.................. - 10
>Voltage Settings:
CPU VID Special Add................. - + 225mV
DRAM Voltage Control................ - 2v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.2700v
CPU VTT Voltage..................... - 1.20v
VCore Droop Control................. - Disabled
Clockgen Voltage Control............ - normal
CPU GTL0/2 REF Volt................. - 0.67x
CPU GTL 1/3 REF Volt................ - 0.67x
North Bridge GTL REF Volt........... - 0.63x
FSB Vref............................. - 23
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
Exist Shutdown After AC loss........ - Enabled
O.C Clock Fail Retry Counter........ - 0
O.C Clock Fail CMOS Reloaded........ - Disabled
CPU Clock Ratio..................... - 8
Target CPU Clock.................... - 3,8GHz
CPU Clock........................... - 475
Boot Up Clock....................... - Auto
CPU Clock Amplitude................. - 800mV
CPU Clock0 Skew..................... - 400ps
CPU Clock1 Skew..................... - 400ps
DRAM Speed.......................... - 333/667
Target DRAM Speed................... - 950 MHz
PCIE Clock.......................... - 102mhz
CPU Spread Spectrum................. - Disabled
PCIE Spread Spectrum................ - Disabled
