CroniC88
bei mir scheint der SATA-Controller auf dem ICH10 defekt zu sein... ich hab lange rumprobiert bis ich zu dem festen entschluss gekommen bin... hatte das schon jemand?
Target: 4.1GHz
BIOS Version 12/29/2008
Exit Setup Shutdown……Mode 2
Shutdown After AC Loss……Enabled
AC Shutdown Free……Enabled
OC Fail Retry Counter……1
OC Fail CMOS Reload……Disabled
CPU Clock Ratio……9x
CPU N/2 Ratio……Disabled
Target CPU Clock……4104 MHz
CPU Clock……456
Boot Up Clock……Auto
CPU Clock Amplitude……800mV
CPU Clock0 Skew……0ps
CPU Clock1 Skew……0ps
DRAM Speed……333/667(andere settings auch versucht)
Target DRAM Speed……DDR2 914
PCIE Clock……100 MHz
CPU Spread Spectrum……Disabled
PCIE Spread Spectrum……Disabled
CPU Feature Page
Thermal Management Control……Enabled
PPM (EIST) Mode……Enabled
Limit CPUID MaxVal……Disabled
C1E Function……Enabled
Execute Disable Bit……Disabled
Virtualization Technology……Disabled
Core Multi Processing……Enabled
DRAM Timing
Enhance Data Transmitting……Normal
Enhance Addressing……Normal
T2 Dispatch ……Disabled
Flex Memory Mode……Auto
Cas Latnecy Time (tCL)……5
RAS# to CAS# Delay (tCRD)……5
RAS# Precharge Time (tRP)……5
Precharge Delay (tRAS)……15
All Precharge to Act……5
REF to ACT Delay (tRFC)……60
Performance LVL (Read Delay)……Auto /10/11/12 versucht
Read delay phase adjust……N/A
Write to PRE Delay (tWR)……Auto
Rank Write to Read (tWTR)……Auto
ACT to ACT Delay (tRRD)……Auto
Read to Write Delay (tRDWR)……Auto
Ranks Write to Write (tWRWR)……Auto
Ranks Write to Read (tWRRD)……Auto
Read CAS# Precharge (tRTP)……Auto
All PRE to Refresh……Auto
Clock Setting Fine Delay
DLL and RCOMP Settings……By Menu (Auto)
CH1 DRAM Default Skew……Model 3
CH2 DRAM Default Skew……Model 3
RCOMP Setting……Model 1
Fine Delay Step Degree……70ps
Ch1 Clock Crossing Setting……Auto (values below auto-generated)
DIMM1 Clock Fine Delay ……2396ps
DIMM2 Clock Fine Delay ……2396ps
Ch1 Control0 Fine Delay ……268ps
Ch1 Control1 Fine Delay ……268ps
Ch1 Control2 Fine Delay ……268ps
Ch1 Control3 Fine Delay ……268ps
Ch1 Command Fine Delay……394ps
Ch2 Clock Crossing Setting……Auto
DIMM3 Clock Fine Delay ……2066ps
DIMM4 Clock Fine Delay ……2066ps
Ch2 Control0 Fine Delay ……48ps
Ch2 Control1 Fine Delay ……48ps
Ch2 Control2 Fine Delay ……48ps
Ch2 Control3 Fine Delay ……48ps
Ch2 Command Fine Delay……394ps
Ch1Ch2 Common Clock Setting……Auto
Ch1 RDCAS GNT-Chip Delay……Auto
Ch1 WRCAS GNT-Chip Delay……Auto
Ch1 Command to CS Delay……Auto
Ch2 RDCAS GNT-Chip Delay……Auto
Ch2 WRCAS GNT-Chip Delay……Auto
Ch2 Command to CS Delay…… Auto
Read Delay Phase Adjust
Ch1 Read Delay Phase (4~0)……12-12-12-12-12
Channel 1 Phase 0 Pull-in……Auto
Channel 1 Phase 1 Pull-in……Auto
Channel 1 Phase 2 Pull-in……Auto
Channel 1 Phase 3 Pull-in……Auto
Ch2 Read Delay Phase (4~0)……12-12-12-12-12
Channel 2 Phase 0 Pull-in……Auto
Channel 2 Phase 1 Pull-in……Auto
Channel 2 Phase 2 Pull-in……Auto
Channel 2 Phase 3 Pull-in……Auto
Voltage Settings
CPU VID Special Add…… +62.5mV
DRAM Voltage Control……1.977V
SB Core/CPU PLL Voltage……1.55V
NB Core Voltage……1.2950 (von 1.25V bis 1.35V probiert)
CPU VTT Voltage……1.30V
Vcore Droop Control……Disabled
Clockgen Voltage Control……3.60V
CPU GTL 0/2 REF Volt……0.67x
CPU GTL 1/3 REF Volt……0.67x
North Bridge GTL Ref Volt……0.67x
FSB Vref…… Auto /21/22
@ Jupiler
Setz mal die VTT etwas tiefer an so auf 1,25 - denn höher ist net unbedingt besser
NB Core ebendfalls auf 1,25v stellen
Wenn er bei höheren FSB net bootet deutet das auch auf falsche GTL's hin - probier mal eine andere NB GTL !
Die GTL's sind das A&O beim DFI
und diese 3 sachen stellst du auch mal auf nominal :
- Ch1 Clock Crossing Setting……Auto
- Ch2 Clock Crossing Setting……Auto
- Ch1Ch2 Common Clock Setting……Auto
2.1-2.2V kannste locker geben, wenn du micron chips hast (was hast du für ram?)
Altaaa wenn ich hier nen FSb 600 lese in ich ziemlich frustrierd -.-"
Ich bekomm noch nicht mal mehr 500 hin....
Ich übernehme einfach mal von oben:
Multi:7
FSB: 500
Clock Amplitude:900mV (800mV, geht schlechter)
Clock 0 skew:200
Clock 1 skew:0 (200, geht schlechter)
Strap: 333/667 (die anderen hab ich schon durchprobiert)
CPU Feature:
Alle auf disabled außer Core Multi Processing
Dram Timing:
Enhance Data Transmitting: Fast (besser als Auto)
Enhance Adressing: Fast (besser als Auto)
T2 dispatch: Disabled
Clock Setting Fine Delay:
Model 3
Model 3
Model 1
Auto
5 <------ WELCHE wERTE GEBEN 5-5-5-15 an (ctrl usw wie heißen die genau?)
5
5
15
Rest auf Auto
Voltage Settings:
Ram: 1,57
NB:1,30
VTT:1,25
Clockgen:3,60
GTL0:0,61
GTL1:0,61
NB GTL:0,58
FSB Ref:Auto
Könnt ihr mir mal die Settings geben, klar is von Mobo zu Mobo unterschiedlich aber ich komm auf keinen grünen Zweig mehr
Hat jemand zwei 4GB Riegel verbaut? Welche könnten gehen auf dem DFI Board?
HI,
mal eine kleine Zwischenfrage schafft jedes DFI Lanparty DK T2RS Plus die 500 FSB mit einem 45nm Quad oder ist das nur einzelnen vorenthalten?
mahaudi schrieb:Schau mal bitte was für Chips deine OCZ Flex II drauf haben !
Entschuldige nur is zwischen Legobyte (altes mb) und DFI ein großer unterschied, weiß nich mal welche Spannung ich erhöhen muss (den Namen) oder wie das jetzt genau mit den RAMs ist.
Aber mach dir mal keine zu große Hoffnungen, hast ja die Ergebnise von meinen gesehen.
Was ich noch fragen wollte, welches Timing meintest du damals am Tel., damit die anstatt 5-6-5-15 mit 5-5-5-15 laufen? Will mal schauen ob es bei den Flex II was bringt.
