[Sammelthread] DFI LANparty UT 790FX M2R / M2RV (AMD 790FX) [1]
Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
IV. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
geht es also doch wenn du anschaltest, also auf "ausgewogen" stellst?
ich frage, weil ich das gerne berichten möchte. scheinen ja nun keine einzelfälle zu sein...
Ja, er stellt den Multi auf 5.75 aber da bleibt er fix ...
auch auf "ausgewogen" nicht auf "energiesparen"??
Meinst du jetzt in den Windows Vista Optionen? Wo finde ich die?
ja in vista:
unter systemsteuerung, hardware und sound, energieoptionen, energiespareinstellungen ändern
wichtig: cpu-z zeigt erst den max takt an, wenn alle cores bzw. der erste zumindestens max takt haben. ebenso everest...
Ja lag daran ... wie dumm von mir ... aber PWMs verdammt heiße scheiße ...
Edit: Kann es sein das der Phenom auch defekte Sensoren hat?
alles klar..
jo kann sein, aber die pwm-sensoren beeinflusst das nicht..
Hab jetzt mal nen 120er davor geklatscht und nun alles extreme kühl PWM ist im Windows nun 51°C ... Bringt es viel die Wp zu wechseln?
bei deinen temps denke ich ja. ich hatte max 80°C auf den pwms und das bei quadprime @ 3,2ghz 1,4v... hatte aber auch den transpiper dran... hast den dran?
Ja der hängt außen vor dem 120er im Rücken des Gehäuses ...
k.. und ist auch mit gut wlp montiert ja?
also die spawas sind dann echt schon sehr heiss...
wennde keinen bock auf wlp wechseln hast kannst ja erstmal mit nem lüfter lassen. ich hatte den lüfter von nem amd boxed cooler auf den spawakühler montiert nd an den nb-lüffianschluss gehängt.. ging auch super..
vielleicht ist es auch der luftstrom im gehäuse.. was haste für nen cpu-kühler?
k... trotzdem luftdurchsatz im gehäuse?
Ja eigentlich schon, ich hab direkt nen 120er im Gehäuse hinten.
Mein CPU schaltet nur zwischen zwei Multis (5.75 und 11.5) her, wodran kann das liegen?
ist normal bei den phenoms...
Mhh ok ....
PS: Wo kann ich den North Bridge Multi einstellen? ^^
unter cpu feature..
der wert nb-fid 05 ist 9x, 04 ist 8x usw., solange du den did nicht veränderst ;)..
Meine Spawas werkeln zwischen 47 und 55°C, dank dem 50er Lüfter den ich draufgeschnallt habe.
Isses vieleicht schlecht, wenn die zu kühl sind?
Hab immer noch das Prob, dass meine Kiste so 1-2 Mal am Tag einfach ausgeht.
nee meine sind wagekühlt in nem ähnlichen bereich und da geht nichts aus..
evtl. doch cpu/ram/nt? wann tritt das auf, idle/last?
Anfangs immer nur im Idle mittlerweilen aber auch in Games.
Die hängen dann aber und er geht nicht aus.
Evtl. doch mal das NT tauschen?
Was mich daran aber stört ist, dass er anfangs, als das Problem auftrat, unter Last nie ne Mucke gemacht hat.
Einfach im normalen Gebrauch, fup und aus.
Was gibt das Board maximal an vcore und vdimm her?
vcore ich glaube 1,6 + 25% (wären 2v, ob das funzt ka)
vdimm auch fast 3v...
@ archon: mmh... wenn mal die möglichkeit hast wegen netzteil probiers mal.
ansonsten testen obs @ stock auch auftritt?
Ich glaube mein Board scheint einen Schaden zu haben. Seit dem ich den Phenom drauf hab (wohl mehr Spannungsbelastung) summt und pfeift irgendwas im Raum der Spannungswandler ... Ich glaube das einzige was ich mit dem teuren Board machen kann, ist wegwerfen ... Was meint ihr?
nö hab ich auch. Ist normal und bekannt bei dem Board. Ist so ein hohes Zischeln, oder?
Ansonsten lieber mir geben als wegwerfen xD
Ja genau so ein zischen, das ist aber am lautesten in meinem PC ... :heul: :fresse: Willste es mir für wenig Geld abkaufen? ^^
Ging die Vdimm nicht bis 4V? ^^
Naja... ich hab heute meine neuen Corsair Dominator 8500 C5 bekommen nur leider mögen die überhaupt nicht auf meinem Board laufen... Mit 2665MHz CPU und 533MHz CL5 2,1V laufen die astrein, aber sobald ich irgendnen anderes Setting reinhau, wo die CPU um die 3GHz läuft und der RAM so 500-550 (verschiedene Spannungen getestet) bleibt der immer bei C1 hängen. Hab schon an allen Timings mal rumgespielt aber nix hat geholfen :grrr: Mit meinen Ballistix läuft die Karre einwandfrei.
Hat jemand mal Erfahrungen mit sowas gemacht? Auf dem 4GB Kit müssten Powerchips drauf sein...
Ansonsten gehen die Teile am Montag zurück :(
