[Sammelthread] DFI LANparty UT 790FX M2R / M2RV (AMD 790FX) [1]
Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
IV. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
lol ich denke die ham die seite lange nicht gepflegt. läuft auf sp3 auf jeden fall super...
Jo, wenn man die Kiste nicht übertakten will.
Ich hatte das Ding schon mal drauf und es ging absolut nix ...
?? kann ich mir kaum vorstellen. haben bei mir nie zicken gemacht die treiber auch beim oc..
aber wurst. viele mögen ja auch kein cnq beim oc, ich habe gerne cnq an..
Ich hätte auch gerne C&Q aber es funt halt nicht.
Mit dem Treiber komme ich gerade aml auf 2,85GHz, mehr geht damit nicht.
Ohne komme ich auf max. 3,1GHz.
lol wie scheisse.. aber dann geht cnq nicht oder doch?
Über was wird hier die ganze Zeit geredet.
Nein, es geht nicht.
Und mit diversen Tools lässt es sich auch nicht verwirklichen.
D.h. Takt lässt sich ändern, aber die Spannungen nicht.
Willste mich verarschen, Öse? :)
nee ich will dich nicht verarschen :d ich will nur wissen: geht es nur ohne treiber nicht aber mit treiber geht es, nur das oc ist dann beschissen, oder geht es überhaupt nicht? weil das sind ja unterschiedliche Sachen...
Sorry wenn das so 'rüberkam ^^ Hatte gestern auch gut 1,5-2L bier intus xD
Kannste das noch mal eben posten, also geht es mit treiber oder nicht? würde mich nämlich sehr wundern wenn es mit treiber nicht geht. Dass das oC beschissen ist mit treiber ist auch komisch, aber dann hätte man das wenigstens getrennt...
Ich mach den Treiber jetzt nicht nochmal drauf ...
Wie geschrieben, ich hatte ihn mal drauf und er taugt nichts.
Das Ding ist von 2007 also fast 1,5 Jahre alt und so ein alter Müll kann nichts taugen! :)
Wenn er dringendst nötig wäre, dann würde er sicher weiter entwickelt.
Der Proz läuft ja auch ohne Probs, nur halt das C&Q geht nicht.
naja ich meinte dann muss man damit wohl leben, auch wenns asso ist.. ich hatte noch nie nen g2 auf diesem board, daher weiss ich dazu nichts...
Bei mir hats bisher mit dem 505 + G2 + Vista funktioniert...
Dann will ich dir raten keins der neueren Biose zuflashen, denn bei mir geht die Spannungänderung selbst nach dem zurückflashen nicht mehr :rolleyes:
oder du probierst es mal und berichtest :d
Ne, also das würde ich niemandem empfehlen!
Bin schon gespannt ob das C'n'Q (dessen Spannungsänderung insbesondere) mit einem Deneb wieder funktioniert oder ob die Biose ab dem 1.12. das jetzt für immer unmöglich gemacht haben.
Würde mich zumindest tierisch ärgern...
vielleicht teste ich den g2 den ich hier habe nochmal auf dem board...
Wäre nett, aber ich denke mal du wirst nur bestätigen was Archon776 und ich geschrieben haben.
Am meisten stört mich aber daran das man es durchs flashen auf ne alte Version nicht wieder zurücknehmen kann...
bevor der deneb reinkommt xD
Genau so siehts aus :d
Dafür muss ich ja dann sowieso wieder auf das Bios vom 26.12. flashen, denn im Bios vom 5.5. wird wohl noch kein Code für die Denebs enthalten sein...
Edit: So, Deneb wurde gerade bestellt, in der Hoffnung das wenigstens er ohne Einschränkungen auf dem DFI rennt.
man kann ihn beim hardwareversand schon kaufen und wird sogar schon ausgeliefert (siehe deneb thread) xD
ansonsten ist nur der 920 gelistet bei geizhals bisher.
@ R.K.: Ob ich Dich wohl erst testen lasse?? xD
Kann leider noch dauern bis ich testen kann, denn der Ram den ich bei HWV dazubestellt habe ist leider nicht lieferbar.
Gestern hieß es noch ab heute wäre er wieder verfügbar, aber seit heute morgen steht unbekannt also Lieferstatus :(
Aber sobald er bei mir ankommt, werd ich auch mal berichten was das DFI so in Verbindung mit dem Deneb kann ;)
welchen Ram haste bestellt?
würde vielleicht hier einer sein board, gegen mein DFI DK 790FXB-M2RS tauschen???
wenn Interesse besteht einfach per PM...
Wie warm dürfen die den PWM werden? Hab seit 10 Minuten meinen TrippleCore drauf und im Windows schon auf 100°C!
Cool'n'Quiet scheint nicht zu funktionieren mit dem neuesten Bios, der verändert den Multiplikator nicht ...
xp oder vista?
pwms auf 100°C ust schon etwas viel. haste den transpiper dran?
Vista hab ich ...
Jetzt sogar auf 110°C ... und der Kühlkörper ist nur handwarm :(
nicht gut.. evtl. mal abnehmen und paste kontrollieren?
und kein cnq unter vista?? bei mir löppt es.. im bios an?
Im Bios ist es auf "Auto" ... Sobald ich Cool'n'Quite an mache ist ja nur noch auf ca. 1 GHz und 1.05V . Da geht auch wieder PWM schön auf 86°C.
