Robust Graphics Booster...............................Auto
CPU Clock Ratio......................................9x
Fine CPU Clock Ratio.................................+0
CPU Frequency.....................................4,50Ghz(400x8,5)
********** Clock Chip Control ********
>>>>> Standard Clock Control
CPU Host Clock Control.............................................Enabled
CPU Host Frequency(Mhz).........................................500
PCI Express Frequency(Mhz)......................................100
C.I.A.2............................................ ......................Disabled
>>>>> Advanced Clock Control
CPU Clock Drive.......................................................700mV
PCI Express Clock Drive....................... .....................700mV
CPU Clock Skew.......................................................0ps
MCH Clock Skew......................................................0ps
********** DRAM Performance Control ********
Performance Enhance...............................................Standard
Extreme Memory Profile(X.M.P.)............ .....................Auto
(G)MCH Frequency Latch..........................................400 / 333
System Memory Multiplier(SPD)..................................2,00D / 2,00B
Memory Frequency(Mhz)........................00...............1000
Dram Timing Selectable(SPD).....................................Auto / Manual
>>>>>Standard Timing Control
CAS Latency Time...................................5.............5
tRCD.....................................................5.............5
tRP.......................................................5.............5
tRAS.....................................................15...........15
Advanced Timing Control:
tRRD.....................................................4.............Auto
tWTR....................................................4.............Auto
tWR......................................................4.............Auto
tRFC.....................................................56...........Auto
tRTP.....................................................4.............Auto
Command Rate(CMD)...............................0.............2
>>>>> Channel A
Channel A Timing Settings:
Static tRead Value..................................11............10 / 9
tRD Phase0 Adjustment............................0..............Auto
tRD Phase1 Adjustment............................0..............Auto
tRD Phase2 Adjustment............................0..............Auto
tRD Phase3 Adjustment............................0..............Auto
Trd2rd(Different Rank).............................6..............Auto
Twr2wr(Different Rank)............................6..............Auto
Twr2rd(Different Rank)..... .......................5...............Auto
Trd2wr(Same/Diff Rank)...........................8...............Auto
DIMM1 Clock Skew Control........................Auto
DIMM2 Clock Skew Control........................Auto
DDR Write Training..................................Auto
Channel A Driving Settings:
Driving Strength Profile................ ...........Auto
Data Driving Pull-Up Level........................Auto
Cmd Driving Pull-Up Level........ ................Auto
Ctrl Driving Pull-Up Level................ .........Auto
Clk Driving Pull-Up Level..........................Auto
Data Driving Pull-Down Level....................Auto
Cmd Driving Pull-Down Level.....................Auto
Ctrl Driving Pull-Down Level......................Auto
Clk Driving Pull-Down Level......................Auto
****** Mother Board Voltage Control ******
Voltage Types Normal Current
>>>CPU
Load-Line Calibration Enable
CPU Vcore 1,25000V 1,26875V
CPU Termination 1,200V 1,34
CPU PLL 1,500V Normal [COLOR=Red]1.5V[/COLOR]
CPU Reference 0,760V Normal [COLOR=Red]1,34*0,63=0,8442[/COLOR]
>>>MCH/ICH
MCH Core 1,100V [COLOR=Red]1,3 versuchen[/COLOR]
MCH Reference 0,760V Normal [COLOR=Red]1,34*0,63=0,8442[/COLOR]
MCH/Dram Reference 0,900V Normal [COLOR=Red]2,1/2=1.05[/COLOR]
ICH I/O 1,500V Normal
ICH Core 1,100V Normal
>>>DRAM
DRAM Voltage 1,800V 2,100V
DRAM Termination 0,900V Normal [COLOR=Red]2,1/2=1.05[/COLOR]
Channel A Reference 0,900V Normal [COLOR=Red]2,1/2=1.05[/COLOR]
Channel B Reference 0,900V Normal [COLOR=Red]2,1/2=1.05[/COLOR]
Advanced BIOS Features:
Limit CPUID Max. to 3 Disabled
No-Execute Memory Protect Enable
CPU Enhanced Halt(C1E) Disabled
C2/C2E State Support Disabled
C4/C4E State Support Disabled
CPU Thermal Monitor 2(TM2) Enabled
CPU EIST Function Disabled
Virtualization Technology Disabled
