C
cyphermax
Guest
Mahlzeit Cole,
wieviel pll soll ich geben,reichen 1,500?
vtt wieviel?
vtt wieviel?
Mahlzeit Cole,
vtt wieviel?
Kann ich das über ET machen oder besser im Bios?
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 9
CPU Frequency ...........................: 4.00Ghz(445x))
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: enabled
CPU Host Frequency (Mhz) ............: 445
PCI Express Frequency (Mhz) .........: Auto
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 700mv
PCI Express Clock Drive.................: 700mv
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance...................: Standard
Extreme Memory Profile (X.M.P.).....: ?
(G)MCH Frequency Latch...............: 400Mhz
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: 890
DRAM Timing Selectable ................: Auto
Standard Timing Control
CAS Latency Time........................: 5.......Auto
tRCD .........................................: 5......"
tRP'...........................................: 5........"
tRAS..........................................: 15......"
Motherboard Voltage Control:
Loadline Calibration.………................ Disabled
CPU Vcore….……….........................: 1.25625V
CPU Termination…..... 1.200V*.......: Auto
CPU PLL…………………....1.500V*.......: 1.500V
CPU Referen.…………....0.760V*.......: Auto
MCH/ICH
MCH Core…………….....1.100V...........: 1.180V
MCH Reference….…….0.760V...........: Auto
MCH/DRAM Ref.…......0.900V...........: Auto
ICH I/O……………….....1.550V............: Auto
ICH Core…………...……1.100V............: 1.200V
DRAM
DRAM Voltage ……....1.800V............: 2.100V
DRAM Termination .…0.900V............: Auto
Channel A Reference 0.900V............: auto
Channel B Reference 0.900V............: Auto
Weil 99% aller Q9550 Q9650 TJMax 100 haben....(man weiß nie, obs doch 105er gibt)
Lad doch bitte das neueste runter. Weiß ned was das für ne Beta ist, aber nicht gerade vertrauenswürdig. Du wirst sehen, aus 39 werden 44°
Das sind Load unter 1.2V....Sinn? Wenn ja ist es die beste CPU dies gibt, was ich aber erst mit nem prime screen sehen will![]()
ne teclia und Joker ham die besten(es wird immer bessere geben)
Ich meins nur im guten, bevor alle 400 euro für dieCPU ausgeben![]()
So und jetz prime small bitte laufen lassen
teclia hat oc liste 531x8.5denke nicht, dass der 0.5 so auslässt
Diese Werte sind im Bios eingegeben.
Hallo Leut
Habe heut mein neuesGigabyte GA-EP45-UD3P
bekommen.
Nun wollt ich gern wissen welche Board Treiber ich nehmen kann, die von
der CD oder soll ich mir neue herunter laden?
Und Welches Bios ist das beste für den Q9650?
Ich Dankeuch für eure Hilfe im voraus.
Bios F7 und F9 sind gut zum Oc
Treiber kannst von CD nehmen
Beim Flashen.... am besten per USB-Stick und mit Q-Utiltiy Flash & Anleitung
@White,er hat UD3P...nicht R...da ist defintiv F7 oder F9 das beste!!!
was ist die aktuelle primeversion für vista 64?
