[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Hallo zusammen,
habe mich grad hier durchgearbeitet und nicht wirklich eine Antwort gefunden. Vielleicht hat jemand die gleiche Konstellation und kann mir eine Antwort geben :-)
Ich möchte nach langer Zeit mal wieder aufstocken und habe für den ins Auge gefassten 5950x 2 Boards im Blick.
Das MSI MEG X570S Ace Max und das MPG X570S Carbon Max Wifi, weil das die einzigen Boards oder Chipsatzlüfter sind die zu meinem Nutzungsverhalten passen würden.
Meine Frage wäre....beide Boards haben 8x SATA 6Gb Ports.....ich möchte 2x M.2 SSDs reinpacken und alle 8 SATA Ports nutzen können.
Wenn ich eine M.2 in den M2_1 Platz vom Prozessor und die zweite in den M2_2 vom Chipsatz packe, müssten doch alle 8 SATA Ports nutzbar sein...oder?
Zumindest entnehme ich das so aus den Handbüchern.
Vielleicht hat jemand auch Erfahrung mit den beiden Boards und kann mir die Wahl erleichtern. 8-)
Würde mich sehr über eine Antwort freuen.
Besten Dank im Voraus....
LG Maxe..
@ra773
Hi das mit USB ausfällen habe ich bei mir auch.
Manchmal braucht das USB bei Start ziemlich lange, oder beim Zocken geht Tastatur bzw der USB Stick vom Controller plötzlich offline.
Ist nicht oft der Fall aber es passiert.
Bei mir ist es noch das letzte Beta-Bios
sehe gerade dein 5800x3d rennt auf allcore.
wie warm wird der mit mora unter 100% last.
wie kann man auf die unify mit dem 5800x3d ein fixed all core machen ?
bei mir gibt es dafür nirgendwo eine option.
@ra773
Also ich bin mit Kombostrike 3 und FSB 102,2 auf die 4,55 gekommen.
Unter Volllast mit zb CB23 komme ich auf ca 80° im silent modus.
Wenn ich die Lüfter Testweise voll laufen lasse komme ich auf 76° runter.
@ra773
Ich habe jetzt den aktuellen Chipsatztreiber installiert,
Dort ist ein neuer USB Treiber enthalten seitdem (klopf auf holz) habe ich keinen Abbruch des USB mehr gehabt
@ra773
USB Ausfälle gibt es bei AMD, wenn die Spannung zu tief sinkt an der CPU. "Global-C State" muss im Bios AUS sein.
Ebenfalls werden die USB Ports instabiler, je höher der Infinity Fabric ist! Dann muss man die SOC Voltage erhöhen.
MSI hat nach dem AB3 BIOS die CPU Spannung erhöht im default. Deshalb takten die CPUs nicht mehr so hoch, seit dem folgendem BIOS.
Das beste BIOS ist meiner Meinung nach das AB3.
Fun Fakt: Das gleiche USB Problem habe ich bei meinem Ryzen 7900X und einem B650 Board auch.
Mit dem neusten Chipsatztreiber hat AMD die IDLE Spannung schon wieder erhöht. Früher war die mal 0,400V heute immer über 1,000V
Kann ich so bestätigen -ich dachte schon, bei mir ist was faul.
Hm, muss ich noch mal genauer gucken.
Mir ist nur die scheinbar dauerhaft hohe Idle-Spannung aufgefallen.
Hey Leute, mal eine Frage. Ich krieg auf meinem Unify keinen RAM mit XMP zum laufen (aktuell den G.SKill F4-3200C14D-32GVK), trotz angeblichem Support laut QVL. Kann das Board die Ursache sein? Ich hatte das Problem mit zwei verschiedenen 5950x und einem 5800X3D. Vor allem läuft der RAM auf anderen Boards. Wenn ich XMP deaktiviert lasse läuft alles wunderbar. Auch Timings entschärfen, RAM Takt runterschrauben etc war erfolglos.
Also standardmäßig wird bereits eine Spannung von 1,376V angelegt, wenn es auf Auto steht. 1,4V habe ich noch nicht getestet. Der RAM hat Samsung B-Die. Sollte ja eigentlich besser laufen als andere Sticks.
Wie warm wird denn Dein Speicher.
Ich habe bei mir, Wasserkühlung von GPU und CPU festgestellt, dass ein Lüfter, der nun auf der GPU steht und Richtung Ram pustet bei B-Die Wunder bewirkt.
Grundsätzlich sollten die 32GB 3200 cl 14 aber so laufen, dass tuen sie bei mir auch mit XMP.
Ich habe bei mir einfach "XMP" laufen und bin dann auf 3400mhz gegangen. Bei 3600 müsste ich optimieren und da habe ich keine Lust zu, da beim 5800x3d das eh nicht so viel bringt.
Spannung laut HWInfo bei 1,36v.
VG
Der RAM wird so 40°C warm. Eigentlich im Rahmen oder? Hab auch direkten Airflow auf den Ram. Ich hab jetzt mal ein Kit von von TeamGroup bestellt mit CL18 und 3600mhz. Der ist auch auf der QVL. Wenn hier das gleiche Problem besteht, gehe ich davon aus, dass es am Board liegt. Ich hatte das Unify in meinem Arbeitsrechner durch ein X570-E von Asus ersetzt und da keine Probleme mehr mit der gleichen Hardware, die vorher auf dem Unify lief. Wenn mal ein paar Seiten zurückgeht sieht man die Probleme die ich mit dem RAM und dem Board hatte. Hat jemand Erfahrung mit Reparatur bei MSI? Konnte auf deren Webseite nichts finden. Mainboards werden von RMA wohl ausgeschlossen.
Bios downgrade mal versucht? Agesa 1.2.0.7 ist was Ram anbelangt zum kotzen...
Das wusste ich nicht. Nein, das hatte ich noch nicht ausprobiert. Mache ich später mal.
Bevor du das machst würde ich erst einmal ein CMOS Clear versuchen. Falls noch nicht getan und es hier noch nicht vorgeschlagen wurde. Habe nicht alles gelsen.
CMOS Clear hatte ich vor der Installation der neuen CPU gemacht, da ich das Bios des Motherboards ohne CPU ohnehin updaten musste für den 5800X3D. Also Batterie für 20min rausgenommen und dann geflashed.
Nach dem Flash auch ein CMOS Reset gemacht?
Klingt unsinnig, hilft aber durchaus.
Das hatte ich nicht gemacht. Klingt in der Tat unsinnig. Das heißt ich nehme das Board vom Strom und drücke dann den Button an der Rückseite?
Der RAM sollte auch im XMP ohne weiters laufen, ist ja "nur" 3200C14. Du hast 4x16 oder? Mal mit 2x16 in A2/B2 probiert? Ansonsten würde ich auch das Board als Übeltäter vermuten.
kann ich nicht bestätigen. Ich hab meinen RAM OC vom 5800X mit der 1.2.0.2 Agesa auf den 5800X3D 1.2.0.7 übernommen und das läuft stabil. 3200C14 B-Die auf 3800C15 GDM OFF.
Es sind 2x16Gb. Habe den Clear CMOS gemacht und dann Memtest 16 Instanzen laufen lassen über Nacht. War jetzt ohne Error nach 600-800% und hatte auch keine Hänger mehr in Windows. Scheint also geholfen zu haben *Daumen drücken*
Moins,
ich habe auch nochmal ein Thema mit dem x570 Unify.
Ich erlebe ständig Aussetzer mit PCI-E Karten.
Ich habe neben der 3080ti im Slot daneben eine Soundblaster Ae-5 und im untersten Slot eine 10Gb Netzwerkkarte.
Zusätzlich sind die M2 alle belegt.
Es kommt öfter vor, dass nach einen Kaltstart die Soundkarte nicht richtig initialisiert oder aber die Netzwerkkarte zwar erkannt wird, aber keine Verbindung aufbaut. Es hilft immer nur ein Neustart.
Gibt es da jmd der sowas auch erlebt oder irgendwelche notwendigen Einstellungen um das zu verhindern?
Viele Grüße
In welchen Slots stecken denn die jeweiligen Karten?
Sind die M.2 alle NVMe oder auch SATA mit dabei?
Die M.2 sind 2 NVMe und eine kleine SSD Barracuda
PCIe 1 ist 3080ti
PCIe 2 Soundkarte
PCIe 3 leer
PCIe 4 leer
PCIe 5 10gb Doppel Netzwerk
Soundkarte lief aber auch schon in PCIe 4 und ändert nix.
Immer wieder ist mal irgendwas nicht richtig aktiv .
Entweder die SB wird nicht gefunden oder Netzwerk geht erst beim 2. Start.
nervt.
Wie sind denn die Spannungen?
