[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Vielleicht ist jetzt undervolten möglich
werde es diese Woche noch testen
Kannst du auf Anhieb sagen, welche dies sind?
Auf jeden Fall mit "Kombo Strike" Option. Das sind vorgefertigte CO Profile mit -10, -20 und -30. Bin mir jetzt nicht sicher ob auch CPU Voltage Offset, PBO Limits und der CO Allgemein freigeschaltet sind.
Hmm, da ging seit langem mal ein BIOS Update schief.
Hab das neueste für mein x570s Unify per MSI Center update versucht, jetzt steckt das ganze fest, Debug LED zeigt #22
Werde mal einen force flash per usb stick versuchen.
/edit/
Flash per USB hat zum gleichen Ergebnis geführt, aber Clear CMOS hatte Erfolg
Würde ich in Zukunft einfach lassen und das BIOS entweder direkt per M-Flash oder per Flashback flashen.
Jupp, war faul. Mach es sont immer per M-Flash
Hab jetzt mal alles durchgeschaut und keine UV Funktion gefunden :(
Mein Unify macht gerade Probleme mit Handbreak (5600X). Ich habe alles an OC (auch Curve Optimizer) deaktiviert und es rebootet trotzdem noch das System. Ich möchte einen BIOS Reset machen und in dem Zuge gleich auf eine aktuellere BIOS Version. Welche kann ich da ruhigen Gewissens nehmen? 7C35vAE1?
Ich habe aktuell die AD am laufen mit AGESA 1.2.0.7 und läuft bei mir bisher problemlos.
Ich habe die Beta seit ein paar tagen laufen und mir ist nichts negatives aufgefallen.Alles läuft wie gehabt (y)
Was muss ich im UEFI so einstellen, dass mir Windows 10 wieder anzeigt, das mein System nicht für Windows 11 kompatibel ist?
Ich mein, ich habe im UEFI schon was am TPM-Modul eingestellt, nur kam jetzt die Meldung, dass Windows 11 zur Installation bereit Stände. Damit sich das nicht automatisch installiert, würde ich gerne wieder die Kontroller darüber erlangen und dazu muss man im UEFI nur eine oder auch zwei Einstellungen machen, womit wieder das Testsystem meint, mein Rechner wäre auf Grund des fehlens des TPM 2.0 Moduls nicht für Windows 11 bereit.
Hier mal ein Screenshot wo es zu finden ist.
Security Device Support auf Disable.
Also mein System ist seit Ewigkeiten Win11 kompatibel, aber von alleine passiert hier kein Update.
@derin: Das das Upgrade sich selbst noch nicht einspielt liegt dann doch an der Microsoft-Strategie. Nur werden die es irgendwann so hindrehen, dass dieses Upgrade sich von selbst installieren wird. Hat man doch vom Wechsel von Win7 auf Win10 gesehen.
Hi ich bin seit kurzem stolzer Besitzer des X570 Unify mit einem 5800X3D
Ich wollte mich mal an den BCLK machen, doch wenn ich nur um 0,1 erhöhe hängt das Board ewig am Post A2. Es bootet dann durch.
Ich bin schon bis 103,3 MHz was bisher stabil läuft leider mit fast 3 Min Bootzeit nicht zu ertragen.
Hat da jemand einen Tipp für mich wie ich das Problem umgehe?
Ich habe das aktuelle Beta Bios drauf.
Hab einen Tip, lass den BCLK wie er ist, der Ryzen 5800x3d mit Stock 4450 Mhz ist schnell genug.
Selbst mit 4740 Mhz war der fps boost in games eine Lachnummer
Ich verstehe es auch nicht wirklich, warum man den X3D via BCLK unbedingt übertakten muss. Einfach Stock laufen lassen, er bietet so schon immens viel Leistung in Games.
Hi das dass OC nicht nötig ist und ob es was bringt sei dahingestellt.
Es ging mir ja nicht ums OC ansich sondern ob jemand weiss warum der a2 Post so lange stehen bleibt und ob sich das umgehen liese.
Ich nehme an das der veränderte BCLK auf so ziehmlich alles einfluss nimmt und bei zunehmender abweichung alle werte nachkalkuliert werden müssen und das betrifft nicht nur den nackten cpu tackt.Ich glaube nicht das sich das umgehen lässt.
Für das x570 Unify gibt es eine neue LED Firmware Update über das neue MSI Center.
Benutzt wer das MSI Center? Habe mit dem Dragon Center sehr schlechte Erfahrungen gemacht und das wieder aus Windows zubekommen war auch nicht schön.
Durch das Dragon Center hat damals mein Ryzen rumgesponnen.
Notfalls vor der Installation des MSI-Centers ein Backup von Windows machen. dann die Software installieren und das Firmware-Update durchführen. Anschließend das zuvor erstellte Backup wieder einspielen. ;)
Nur wenn ich vor habe die Platte zu formatieren, installiere ich das MSI Center für Updates.
:fresse2: Okay, ist also das Programm immer noch schlecht. Ich lasse es mit dem Center :bigok:
Ich weiß nicht, wie gut oder schlecht das MSI-Center ist. Zuvor habe ich es so mit dem ehemaligen Dragon-Center gemacht.
Hm... -laut Systeminfo vom MSI-Center habe ich die Version A7 und mir wird unter Live Update (auch nicht unter Erweitert) kein Update angeboten.
EDIT:
Dafür habe ich eben die Treiber der Netzwerkkarte direkt von der Realtek-Seite aktualisiert und das MSI-Center zeigt mir noch immer den alten Netzwerkkartentreiber an.
Unter Windows wird die aktuelle Version richtig angezeigt.
Jemand schon AE2 getestet für das Unify?
Edit: Hab es geflasht und mal testen.
Dankeschön, habe mich nur gewundert das es wieder weg ist! Ich warte, will kein Beta-BIOS.
