Running GPU benchmark 1
Results will depend on current system settings
Drücken Sie eine beliebige Taste . . .
Running...
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 71.35s, Average FPS: 28.03
Min FPS: 6.86 at frame 140, Max FPS: 41.23 at frame 971
Average Tri/Sec: 26355410, Tri/Frame: 940284
Recorded/Played Tris ratio: 0.97
!TimeDemo Run 1 Finished.
Play Time: 60.07s, Average FPS: 33.30
Min FPS: 6.86 at frame 140, Max FPS: 47.91 at frame 73
Average Tri/Sec: 31598542, Tri/Frame: 949020
!TimeDemo Run 2 Finished.
Play Time: 59.97s, Average FPS: 33.35
Average Tri/Sec: 31653762, Tri/Frame: 949122
!TimeDemo Run 3 Finished.
Play Time: 60.11s, Average FPS: 33.27
Average Tri/Sec: 31633724, Tri/Frame: 950744
Recorded/Played Tris ratio: 0.96
TimeDemo Play Ended, (4 Runs Performed)
Play Time: 68.21s, Average FPS: 29.32
Min FPS: 16.81 at frame 152, Max FPS: 41.65 at frame 986
Average Tri/Sec: 30897568, Tri/Frame: 1053712
Recorded/Played Tris ratio: 0.87
Play Time: 62.90s, Average FPS: 31.80
Average Tri/Sec: 33876464, Tri/Frame: 1065388
Recorded/Played Tris ratio: 0.86
Play Time: 62.98s, Average FPS: 31.76
Min FPS: 16.81 at frame 152, Max FPS: 41.85 at frame 1006
Average Tri/Sec: 33842020, Tri/Frame: 1065610
Play Time: 63.02s, Average FPS: 31.73
Min FPS: 16.81 at frame 152, Max FPS: 42.62 at frame 997
Average Tri/Sec: 33828196, Tri/Frame: 1065970
Play Time: 86.12s, Average FPS: 23.22
Min FPS: 14.61 at frame 1945, Max FPS: 38.20 at frame 1757
Average Tri/Sec: -17058722, Tri/Frame: -734530
Recorded/Played Tris ratio: -1.25
Play Time: 75.55s, Average FPS: 26.47
Min FPS: 14.61 at frame 1945, Max FPS: 38.56 at frame 85
Average Tri/Sec: -19140176, Tri/Frame: -723049
Recorded/Played Tris ratio: -1.27
Play Time: 76.32s, Average FPS: 26.21
Min FPS: 14.60 at frame 1941, Max FPS: 38.56 at frame 85
Average Tri/Sec: -18926706, Tri/Frame: -722212
Play Time: 76.91s, Average FPS: 26.01
Average Tri/Sec: -18783188, Tri/Frame: -722273
Play Time: 86.20s, Average FPS: 23.20
Min FPS: 14.79 at frame 1944, Max FPS: 37.47 at frame 993
Average Tri/Sec: -17029484, Tri/Frame: -733978
Play Time: 75.82s, Average FPS: 26.38
Min FPS: 14.69 at frame 1949, Max FPS: 38.67 at frame 83
Average Tri/Sec: -19064936, Tri/Frame: -722704
Play Time: 76.62s, Average FPS: 26.10
Min FPS: 14.66 at frame 1942, Max FPS: 38.67 at frame 83
Average Tri/Sec: -18836208, Tri/Frame: -721598
Play Time: 77.18s, Average FPS: 25.91
Min FPS: 14.32 at frame 1947, Max FPS: 38.67 at frame 83
Average Tri/Sec: -18704194, Tri/Frame: -721780
Play Time: 87.05s, Average FPS: 22.98
Min FPS: 14.75 at frame 1949, Max FPS: 38.25 at frame 991
Average Tri/Sec: -16881236, Tri/Frame: -734752
Play Time: 75.12s, Average FPS: 26.62
Min FPS: 14.75 at frame 1949, Max FPS: 39.00 at frame 1758
Average Tri/Sec: -19242072, Tri/Frame: -722745
Play Time: 75.93s, Average FPS: 26.34
Average Tri/Sec: -19016570, Tri/Frame: -721934
Play Time: 76.50s, Average FPS: 26.15
Min FPS: 14.65 at frame 1949, Max FPS: 39.00 at frame 1758
Average Tri/Sec: -18872674, Tri/Frame: -721841
Play Time: 69.12s, Average FPS: 28.94
Min FPS: 11.86 at frame 149, Max FPS: 44.71 at frame 993
Average Tri/Sec: 29336284, Tri/Frame: 1013830
Recorded/Played Tris ratio: 0.90
Play Time: 61.24s, Average FPS: 32.66
Min FPS: 11.86 at frame 149, Max FPS: 46.68 at frame 97
Average Tri/Sec: 33494742, Tri/Frame: 1025539
Recorded/Played Tris ratio: 0.89
Play Time: 61.22s, Average FPS: 32.67
Min FPS: 11.86 at frame 149, Max FPS: 47.20 at frame 991
Average Tri/Sec: 33528564, Tri/Frame: 1026300
Play Time: 60.99s, Average FPS: 32.79
Average Tri/Sec: 33620724, Tri/Frame: 1025226
1280x1024, xp32, high, 169.21
denke es liegt bei mir an der schwachen cpu
