[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Das LED Firmware Update ist über 2 Monate alt (und hat einen nervigen Fehler behoben)
Nun MSI Center hat es mir jetzt erst angeboten obwohl ich das öfter überprüft hatte.
Hatte ein Problem mit Sound/Gerätetrennung was letzten Endes am Mystic Light lag
Gibt jetzt auch ein finales Bios. Das Build Date von diesem ist aber vom 20.05.
Heißt die AD3 ist neuer als das finale Bios.
Also besser das AD3 flashen weil neuer ob wohl Beta?
Von der Theorie her ja.
Ist jemand im englischen MSI Forum registriert? Dann könnte er dort bei Pangolin mal anfragen ob es einen Changelog für die AD3 gibt. Vom ihm stammt ja diese Version.
Ja bin dort registriert. Werde mal anfragen.
Also ist die Beta wieder Final geworden. Die hatte ja auch Build Date 20.5, wenn ich mich recht erinnere? Fahre mit der auch gut bisher.
Hatte bei 1.2.0.3b mit CO immer wieder WHEAs damals und musste bis auf -5 runter. Aus irgendeinen Grund läuft 1.2.0.7 aber hier wesentlich besser und konnte x-mal weiter runter (s.unten). Hab gerade irgendwie keine Lust nochmal dieses Rodeo durchzumachen für ein neues Build :) Infos über Änderungen wären dann super, danke!
Eben diese Antwort bekommen vom ihm.
https://forum-en.msi.com/index.php?...troubleshoot-and-features.358841/post-2087045
should be identical but MSI just builds AD0 for mass production.
I have no access to changelog for each BIOS release unfortunately.
Wenn also beide Ident sind, ob wohl zu unterschiedlichen Zeit kompiliert ist es egal, ob man AD oder AD3 flasht. Ich lasse jetzt die AD3 darauf da vorhin geflasht.
AD2 - 09.05
AD0 - 20.05
AD3 - 02.06
Macht halt eigentlich keinen Sinn eine neue Beta raus zubringen, wenn man bereits eine finale hat.
Vielleicht hat ja jemand die Zeit und Lust die Versionen miteinander zu vergleichen :d
Stimmt, kann nur das wiedergeben, was er mir zurückschrieb,
Würde mich nicht wundern, wenn MSI die Version (quasi AD2) wieder zurückzieht, wie sie es bereits mit der AB-Version getan haben. Ich werde noch etwas abwarten.
Funktioniert bei mir einwandfrei mit nem Ryzen 5800x3D
Hoffentlich implementieren sie noch die VCore ins BIOS, würde den gerne etwas undervolten.
Kannst du ansonsten auch mit dem PBO2 Tuner unter Windows machen.
Gibt es für den PBO2 Tuner auch werte für einen 5600x?
Jede CPU ist anders und es gibt keine allgemein gültigen CO Werte dafür. Selber rausfinden bis das System instabil wird oder WHEAS, hauptsächlich im Idle, auftreten.
Ryzen Master in der neuen Version kann relativ gute Werte ermitteln dauert ca 2-3 Stunden.
Welche Agesa rennt denn momentan am Besten für Single Core Boost? Ich habe die 1.2.0.3.C drauf...
Mit dem 5800X3D habe ich nun derzeit die Wahl zwischen AGESA 1.2.0.6c und 1.2.0.7 und mit letzterem Update ist mein System spürbar flinker geworden. Zudem wird nun hoffentlich das fTPM-Problem der Vergangenheit angehören.
Ich habe immer noch das AD3 und kann mich nicht beklagen alles läuft wie es soll.(y)
MEG X570S UNIFY-X MAX !!​
AMI------- BIOS7D51v13---------2022-06-13 !!
- Update to AGESA ComboAm4v2PI 1.2.0.7. - Change the default setting of Secure Boot.
Lg
AMI BIOS7D51v141 (Beta version) 2022-06-29 - 17.62 MB
  • Beschreibung - Improved CPU performance of Ryzen 7 5800X3D.
  • lohnt sich das Bios Beta nur wenn mann ein 5800X3D oder auch ein 5950X hat ...?
Lg
Das Bios hat nur zusätzliche Optionen für den X3D bekommen.
