[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Downgrade sollte doch problemlos gehen.Aber wenn ich so lese glaube ich wäre es besser die cpu einzuschicken wenn die so heiß wird.
Aktuell bei 79°C auf einem CCD nach 1 1/2 Std zocken. Keine Ahnung, ob das zuviel ist. Schwer einzuschätzen
Ganz ehrlich deinem kühler würde ich null vertrauen der wäre mir einfach zu klein für dieses biest von amd.
Dabei bin ich extra auf den 280er umgestiegen und andere kriegen doch nen 5950X selbst mit nem Dark Rock Pro 4 gekühlt. Aber der Umtausch kann sicher dauern.
Ich halte meinen mit einer wasserkühlung in schach damit der ordentlich boosten kann wenn leistung verlangt wird.
Was hast du im Bios so eingestellt? Gibt es da irgendwas, dass ich übersehe?
Wie ich feststellen muss läuft der IF1866 problemlos mit angepassten Ram timings :banana:nur der 1900er verweigert noch den dienst.
Bei mir läuft der RAM jetzt auch endlich 3800/1900 stabil. C16/18/18/18.
Jetzt fehlen nur noch 100mhz 😂
Edit. Aber das stock boost Verhalten der CPU ist deutlich schlechter als mit A82.
Mit A82 sehe ich immer wieder mal 5ghz in Game Benchs, mit A8 ist bei 4,9 schluss. C23 single Core A82 1630 bis 1650Punkte, A8 1540 bis 1560 Punkte.
Takt cb23 A82 4925 bis 5000mhz, A8 4800 bis 4875mhz.
PBO aus.
Bin wieder zurück auf A82, jetzt passt es wieder.
PBO aus.
Genauso wars bei mir auch. Überlege ebenfalls zu A82 zurückzugehen. Aber bei A80 Final habe ich keine Ruckler mehr beim Systemstart oder beim schließen/öffnen gewisser Programme.
Du meinst das Laggen des Mauszeigers beim Starten mancher Programme? Die Lags hatte ich auch mit meinem alten PC (i7-8700K und Z370-Mainboard). Daher schiebe ich das eher auf Windows 10.
Kommt drauf an, welche Version installiert ist. Seit 2003 sind mit dem 8700K die Lags vorhanden. Nun mit dem Ryzen und 20H2 ebenfalls noch. Aber das Problem tritt nur mit manchen Programmen und dann auch nur beim ersten Start des Programms auf. Stört mich nicht weiter...
servus
hab seit 1monat das ACE und bin ganz zufrieden.
Jetzt hab ich seit kurzem, das der PC nichtmehr aus dem Kaltstart morgens startet. Nur der ON Board Powerknopf leuchtet. einmal ist der PC durch betätigung des knopfes gestartet-- (PC ON am Gehäuse ging nicht). Aber heute half das auch nicht. Kein Muks.
Erst nach einem BIOS reset gings dann wieder.
sehr seltsam.
Anfürsich lief alles bestens- Zocken-Benchmark - neustart- einfach alles.
Jetzt das...
IMMO PBO enable-CO minus10- sonst eigentlich nichts verändert.
vorrher mit ordentlich OC lief auch alles super. war mir aber zu hitzig der 5800X :d
alles sehr plötzlich- wenn ser läuft dann läuft der PC-Ohne Murren.
jemand ne idee? NT ??
ACE X570
5800X
6900XT
NT Corsair 1200I
UEFI aktuell
gruß
PS: wieso ist denn der ACE Sammelthread wieder zu? :unsure:
Kommt das auch vor, wenn du einfach nur die Default-BIOS-Settings lädst und testweise laufen lässt?
PS: Der ACE-Sammelthread ist wieder zu, weil das ACE nun in diesem Sammelthread mit behandelt wird. Da beide Platinen fast identisch sind, macht das einfach Sinn.
wie gesagt- erst 2x morgens starten wollen. Gestern u heute. Ich trenn den PC immer komplett vom Netz Nachts.
Gestern nur mit onboard, dann Problemlos. Heute nur mit CMOS. dann wieder alles eingestellt.seitdem Problemlos.
HWINFO sagt 11.976 /11.952V auf der 12V schiene.. in IDLE
Eventuell passen die restlichen Spannungen nicht bzw. gerade so, dass das Booten manchmal klappt und manchmal hängen bleibt.
moin- also komisch bei mir- ich habe heute morgen eingeschaltet (pc war nicht vom strom getrennt) ins BIOS geschaut weil die LED nicht an waren.
siehe da, weder der CPU LÜfter noch der Chipsatzlüfter funktionierten.... kein LED-CPU-Chipsatzlüfter. Alle lüfter auf Full-speed gestellt. nix- 0rpm
hochgefahren, rumexperimentiert, gebencht ob die Lüfter angehen, Im Dragoncenter LED aus und an. NIX zu machen.
Dann eher zufällig ein Update der LED Firmware über das dragon gemacht.
Und siehe da, sowohl LED als auch der CPU Lüfter und Chipsatzlüfter gehen wieder..... eher seltsam mit den Lüftern, oder??
servus
sehr seltsam.
Jetzt das...
ACE X570
5800X
6900XT
NT Corsair 1200I
UEFI aktuell
gruß
Also bei mir geht zu 100% reproduzierbar der erste Boot immer in die Hose, Reset drücken und schon klappt es beim zweiten. Habe mich jetzt schon dran gewöhnt...Keine Ahnung was das ist.
Ich hab die erfahrung gemacht das der CO besser pro kern einzustellen ist als alle den gleichen wert zu geben.Weil man genau ermitteln kann wann welcher Kern ab wann instabil wird.
Wenn man z.b generell -10 eingibt schaffen das bei warmen PC alle Kerne aber bei einem kalten ist einer dabei der grenzwertig ist dann klappts erst beim 2. oder 3. versuch.Mach ich das pro Kern kann ich z.b bei einem 12 Kerner 11 mit -15 und den einen mit -9 betreiben was die leistung noch etwas erhöht und auch keine kaltstart probleme macht.
kann da @Chris1975 ganz zustimmen! Meine Kerne (5900X) vertragen soweit alle -15, nur einer ist dabei am CCX2 der dann beim "Kaltstart" manchmal zicken macht (ist auch der Kern, der generell am niedrigsten taketet). Stell ich händisch alle Kerne auf -15 bis und nur den einen auf -10 gibts keine Probleme beim start :)
Kann man sicher mal versuchen
edit* oh das ist ja der 570 Unify thread ^^
Ich hab ein ASRock Taichi, aber ich denk das trifft auch bei den MSI Boards zu
Hallo zusammen
Ich habe auch das ACE und wundere mich über die Ton qualität am hinteren anschlussfeld, ist es möglich das der sabre ess nur für den frontpanel anschluss zuständig ist?
Im verlgeich zu einer asus xonar essence stx II ist die qualität mehr als bescheiden hinten am panel. leider vertragen sich die asus karte und der x570 chip nicht besonders gut, so musste ich die karte wieder ausbauen.
Hallo zusammen
Zum Problem kann ich dir leider nicht helfen aber ne Frage hätte ich trotzdem.
Da ich mir das Board bald zulegen möchte, würde mich interessieren wie der sound unterschied im gegensatz zur stxII ist (am frontpanel)
Alternativ könnt ihr euch die erste Essence STX besorgen, die arbeitet bei mir absolut fehlerfrei. :wink:
