MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 6x
Fine CPU Clock Ratio.....................:.+0.00
CPU Frequency ...........................: 3180Mhz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 530MHz
PCI Express Frequency (Mhz) .........: 100Mhz
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 900mv
PCI Express Clock Drive.................: 800mv
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance...................: [Standard]
Extreme Memory Profile (X.M.P.).....: Auto
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ..............: 2.00B
Memory Frequency (Mhz) ..............: 1060Mhz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................: 5
tRCD .........................................: 5
tRP'...........................................: 5
tRAS..........................................: 15
Advanced Timing Control [Press Enter]
tRRD...........................................: Auto
tWTR..........................................: Auto
tWR............................................: Auto
tRFC...........................................: Auto
tRTP...........................................: Auto
Command Rate (CMD) ....................: Auto oder 2
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value.........................: Auto
tRD Phase0 Adjustmen....................: Auto
tRD Phase1 Adjustment...................: Auto
tRD Phase2 Adjustment ..................: Auto
tRD Phase3 Adjustment...................: Auto
Trd2rd(Different Rank)....................: Auto
Twr2wr(Different Rank)...................: Auto
Twr2rd(Different Rank)...................: Auto
Trd2wr(Same/Diff Rank)..................: Auto
Dimm1 Clock Skew Control...............: Auto
Dimm2 Clock Skew Control...............: Auto
DDR2 Write Training........................: Auto
Channel A Driving Settings [Press Enter]
Driving Strength Profile.................: Auto
Data Driving Pull-Up Level.............: Auto
Cmd Driving Pull-Up Level..............: Auto
Ctrl Driving Pull-Up Level...............: Auto
Clk Driving Pull-Up Level................: Auto
Data Driving Pull-Down Level..........: Auto
Cmd Driving Pull-Down Level...........: Auto
Ctrl Driving Pull-Down Level............: Auto
Clk Driving Pull-Down Level.............: Auto
Channel B
Channel B Timings Settings [Press Enter]
Static tRead Value.........................: 8
Channel B Driving Settings [Press Enter]
Data Driving Pull-Up Level..............: Auto
Cmd Driving Pull-Up Level...............: Auto
Ctrl Driving Pull-Up Level................: Auto
Clk Driving Pull-Up Level.................: Auto
Data Driving Pull-Down Level...........: Auto
Cmd Driving Pull-Down Level............: Auto
Clk Driving Pull-Down Level..............: Auto
{U]Motherboard Voltage Control{/U]
Loadline Calibration.………................ Enabled
CPU Vcore….……….........................: 1,34
CPU Termination…..... 1.100V*.......: 1,2
CPU PLL…………………....1.500V*.......: 1,50
CPU Referen.…………....0.755V*.......: Normal
MCH/ICH
MCH Core…………….....1.100V...........: 1,300
MCH Reference….…….0.800V...........: Normal
MCH/DRAM Ref.…......0.900V...........: AUTO (kann später beim Feintuning des Speichers noch angepaßt werden)
ICH I/O……………….....1.550V............: Normal
ICH Core…………...……1.100V............: Normal
DRAM
DRAM Voltage ……....1.800V............: 2,1
DRAM Termination .…0.900V............: Normal
Channel A Reference 0.900V............: Normal
Channel B Reference 0.900V............: Normal
[b]{U]Advanced Settings[b]{U]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Disabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
